C6 window problem. - Corvette Forum : DigitalCorvettes.com Corvette Forums
Go Back   Corvette Forum : DigitalCorvettes.com Corvette Forums > C6 Corvette Forums > C6 Corvette
C6 Corvette General | Technical | Performance | Aftermarket | Discussions
Old 02-15-2009, 11:16 AM   #1
THE ROCK
THE ROCK's Avatar
Member #50973
2008 3LZ Black Z06 R8C Delivery
C6 window problem.
Hi fellows has there been any issues with windows not returning up when doors close? Windows will vent down when doors are open but not up when doors close. Any help with this issue?
THE ROCK is offline   Reply w/quote Quick reply to this message
Old 02-15-2009, 12:46 PM   #2
1BadMood
1BadMood's Avatar
Member #9239
2007 Triple Black Vert. Z51
While sitting in your car, open and close your door, the window stops about 2 inches short of the top, raise the window all the way, using your button, once it's at the correct position, lock the setting in place using the memory setting button. This should work. It seems to happen when I have had a battery go dead. Hope this helps.
1BadMood is offline   Reply w/quote Quick reply to this message
1BADMOOD
Old 02-15-2009, 06:13 PM   #3
1C62NV
1C62NV's Avatar
Member #66630
06 coupe, man. 6 spd.
it is in your owners manual on indexing windows, I believe its a small section and easy to miss but it does address this issue.
1C62NV is offline   Reply w/quote Quick reply to this message
1 C6 2NV "God Blessed Texas"
503 rwhp 451 ft/lb torque CAM ONLY,pushrods,ultra-lite rocks,and double springs
Old 02-17-2009, 10:24 AM   #4
Phat Chit
Phat Chit's Avatar
Member #46407
1999 torch red C5 sold/2006 Victory Red 3LT Conv.
Ive read that to relearn the window indexing you get in the car start the Aux power.roll the window down and hold the position(button) for five to ten seconds and then roll the window up and hold the position for five to ten seconds .This is supposed to relearn the indexing...Im pretty sure thats how its done Vettes Rule!!!
Phat Chit is offline   Reply w/quote Quick reply to this message
Old 02-18-2009, 02:19 PM   #5
THE ROCK
THE ROCK's Avatar
Member #50973
Great info Thanks
Old 02-18-2009, 02:24 PM   #6
Texdentist
Texdentist's Avatar
Member #76657
I just had to do it this weekend in my 09 coupe. The manual said to open and close the door (with power on), raise window and hold switch for 3 seconds, lower, then raise again and hold switch 3 more seconds. It is then reset.
Texdentist is offline   Reply w/quote Quick reply to this message
Old 02-22-2014, 07:53 AM   #7
ZKI
Registered User
Member #138473
Thumbs up! Window Indexing
Thanks. I just replaced my first battery and had an issue on my 2008 with the window not closing. The indexing worked great.
ZKI is offline   Reply w/quote Quick reply to this message
Old 02-01-2015, 07:00 PM   #8
mikewyc6
Member #151673
c6
hi there im also having trouble with drivers side window on my 06
half the time when i close the door the window wont raise to the top. if im inside it wont let the door open. i have to use the release below. sometimes 10 sec later the window raises then lets inside button work. passenger side works fine. i have re indexed the window several times. battery seems fine. any suggestions
mikewyc6 is offline   Reply w/quote Quick reply to this message
Old 02-02-2015, 05:31 AM   #9
Fluffy
Fluffy's Avatar
Member #68058
JSB 2008 Coupe
Hi,
You're battery could be at the end of it's life or your battery connector is corroded.
Fluffy is offline   Reply w/quote Quick reply to this message
Rayman XIII
Old 02-06-2015, 03:38 PM   #10
chadmac99c5
chadmac99c5's Avatar
Member #56556
2011 Grand sport
My driver window was having problems going down/then up. I re indexed about every 3rd time I opened door. Then I saw that there is a bolt in the window channel that chipped the top on my window... What the Hell ??
chadmac99c5 is offline   Reply w/quote Quick reply to this message
Old 03-14-2017, 09:04 PM   #11
lisamoore1965
Registered User
Member #171490
2007 Corvette
That worked perfectly - Thank you so much!!!!
Vettes do rule!!
lisamoore1965 is offline   Reply w/quote Quick reply to this message
Human Verification
