1980 Door Panel installation - Corvette Forum : DigitalCorvettes.com Corvette Forums
Old 03-14-2017, 10:17 PM   #1
Orozcodr
Orozcodr's Avatar
Member #37941
1980 Corvette 305ci Cal.
I am having trouble getting my door panels to stay attached to the doors. There are no door clips to attach them with for this year. There is only one screw next to the door pillar, one screw that holds the door release covers, and 3 screws that hold the arm rest on. Thats it. Is there a glue to use around the lower edges? I have had no luck with Velcro. Any help would be appreciated.
Orozcodr is offline   Reply w/quote Quick reply to this message
Just Got to live while Im alive!
Old 03-15-2017, 01:41 PM   #2
slofut
slofut's Avatar
Member #119762
1971 base conv. GTO LS1, T56.
No plastic push in fasteners around the perimeter of the door panel? Are there holes for them?
slofut is online now   Reply w/quote Quick reply to this message
Old 03-15-2017, 02:32 PM   #3
corvemon
Member #141705
take it to the dealer
If you take it to the dealer what do they say?
corvemon is offline   Reply w/quote Quick reply to this message
The Following User Says Thank You to corvemon For This Useful Post:
Orozcodr (03-17-2017)
Old 03-15-2017, 04:58 PM   #4
Slow & Leaky
Member #84470
Should be 3 tabs along the bottom, the earlier C3s were Velcro, not sure about yours.
BTW if the door has fit problems like sagged hinges, it may be yanking on the door panel every time it's opened.
good luck with the problem!
Slow & Leaky is online now   Reply w/quote Quick reply to this message
The Following User Says Thank You to Slow & Leaky For This Useful Post:
Old 03-15-2017, 11:41 PM   #5
Metalkid
Member #92641
1978 Silver Anniversary Model #678
There are two long phillips screws w/dress washers, that hold the lower part of the panel.
One is at the front just under the upper vinyl/lower carpet seam, possibly hidden by the map pocket.
Shown here:
http://tech.corvettecentral.com/c3-7...el-removal-10/
The other is towards the rear, behind and below the rear end of the arm rest.
Shown here:
http://tech.corvettecentral.com/c3-7...el-removal-11/
If your screws are missing:
http://www.ebay.ca/itm/Corvette-NEW-...dW~b7u&vxp=mtr
Metalkid is offline   Reply w/quote Quick reply to this message
Old 03-17-2017, 10:23 PM   #6
Orozcodr
Orozcodr's Avatar
Member #37941
Thanks for the pictures. I can now see how they are attached. I have tried glue and Velcro. Nothing seemed to work for very long. Thanks again.
Human Verification
