7 mpg! What is wrong here... - Corvette Forum : DigitalCorvettes.com Corvette Forums
Old 11-20-2012, 01:39 PM   #1
fratelli
fratelli's Avatar
Member #119934
Garage
Put a couple of hundred miles on my '81 Vette. It's got headers and the cat has been cut out with true duals out the back. It is really sucking fuel, something is wrong here. I'm guessing swap out the fuel filter and look for leaks, the carb is overdue for a rebuild, something like that. My nose tells me it is running a bit rich. I know they get bad mileage, but 7 is beyond bad. Any ideas?
fratelli is offline   Reply w/quote
Old 11-20-2012, 01:49 PM   #2
XQIZT
You've been pimped!!
XQIZT's Avatar
Member #80197
1985 Z51
When was the last general tune up? Plugs, wires, cap, rotor, filters of all types, carb cleaning/rebuild.
Timing good?
I am sure there are other things and I am curious to see what others say.
XQIZT is offline   Reply w/quote
"Alexa" - 1985 Z51 - In memory of the last Corvette Dad owned.
Old 11-20-2012, 01:50 PM   #3
6880 Mike
6880 Mike's Avatar
Member #47959
1968 convertible; 1980 L-82
Follow your nose. Smells like time to rebuild your Q-Jet.
6880 Mike is online now   Reply w/quote
Old 11-20-2012, 03:10 PM   #4
7TRoadster
Member #106320
1970 Roadster
Rochester carburetors regularly have an issue with the lead plugs at the lower end of the main jet well. You have to take the throttle plate off to see them.
I cleaned and JB Welded quite a few of these over the years to fix fuel leaks. The leak is a drip but over a tank of fuel a fair amount of fuel can leak out.
It's easy to test, with the bottom off and the open bowl supported on wood blocks fill the bowl about half full of fuel. If they are leaking there will be a small puddle of fuel in 10 minutes or less.
Could be a tuning issue as previously mentioned but my guess is it's carburetor rebuild time. Considering the cost of having a carb done right and you're concern about fuel consumption. Perhaps it might be a good time to think about upgrading to fuel injection?
After all Christmas is coming up.............
7TRoadster is offline   Reply w/quote
Old 11-20-2012, 04:25 PM   #5
rdevaux2007
rdevaux2007's Avatar
Member #52923
2007 LMB, 1977 Coupe
turn back the fuel mix for a quick fix?
rdevaux2007 is offline   Reply w/quote
2007 LMB coupe, m6sp, 3LT.
1977 coupe 4sp
1997 Expedition (sold)
2010 Ford F-150 Supercrew
Old 11-20-2012, 08:19 PM   #6
TimAT
TimAT's Avatar
Member #50735
69 Roadster 454 LS-7 w/ZL-1 stuff inside.
That's probably about what Ol' Red gets. But in reality, I'm feeding a lot of cubic inches and making some fairly large HP numbers..
You should be up in the mid to upper teens at least. I'll bet your carb needs some help.
TimAT is online now   Reply w/quote
Horsepower is like potato chips. If you have 300, you want 500. If you have 500, you want 800. One is never enough.
Old 11-21-2012, 06:23 AM   #7
garys 68
Member #94630
68 vert
No point in even touching anything unless your ignition is working correctly.
Check your distributor timing, dwell, mechanical, and vacuum advance. Also wires, cap, points, etc. the standard tuneup stuff.
Then go to the induction/fuel system. What engine, cam, induction, carb, etc. are you running?
garys 68 is online now   Reply w/quote
Old 11-21-2012, 09:46 AM   #8
fratelli
fratelli's Avatar
Member #119934
Garage
Thanks for all the advice. Thing is, the car starts and runs wonderfully. Turn key-boom on, idles at 900 all day. Sounds beautiful and responds well too. My mechanic suspects the carb as well and he too mentioned fuel injection. I was thinking I could fix it by putting an LS7 motor in there. Might be a little more expensive though. Mechanic can't get to it till spring, I'll update you then. Thanks again.
Old 11-21-2012, 10:29 AM   #9
7TRoadster
Member #106320
1970 Roadster
Hoo yea! on the LS7. I assume you're talking new generation LS7. That is a whole other world of power, weight and economy.
If you're talking the 460 HP big block then gas mileage is about the same as your getting now. My '69 435 HP car got 6 mpg on a good day.
Keep us posted on what you decide.
Old 11-21-2012, 12:19 PM   #10
blckslvr79
blckslvr79's Avatar
Member #67576
1979 L82 4speed
Obama says check your tire pressure.
blckslvr79 is online now   Reply w/quote
Old 11-22-2012, 12:35 AM   #11
fratelli
fratelli's Avatar
Member #119934
Garage
The tire pressure thing is good advice, thank you. I don't think it could account for this much of a loss, but still. It's a safety thing too. I would of course be dropping the new LS7 in there! That thing is wicked. Maybe I can wait for someone to crash a 2013 model and get the first C3 with the new LT1 drivetrain.
Old 11-22-2012, 05:18 AM   #12
c6vettedude
c6vettedude's Avatar
Member #120057
BEAUTIFUL CAR!!
c6vettedude is offline   Reply w/quote
2006 Blk C6 vert w/A&A Supercharger kit w/V3 upgrade, Random Tech ceramic-coated LT headers w/hi-flo cats and Corsa Extreme exhaust. New dyno #'s 611rwhp/583tq
Old 11-22-2012, 06:52 AM   #13
6880 Mike
6880 Mike's Avatar
Member #47959
That's a no-brainer and has been around long before Obama.
Old 11-22-2012, 09:51 AM   #14
gamewood
Member #72090
1991 vette, 1974 vette
my experience....gas leak. though I have a high pressure fuel system that was going through TPiS crappy (cheap) fuel system.
gamewood is offline   Reply w/quote
Old 11-22-2012, 10:08 AM   #15
7TRoadster
Member #106320
1970 Roadster
Take a look at Mast Motorsports for the LS7. Complete crate, with all the cool parts, computer, wiring and already tuned on the dyno.
7 wire hookup, fuse panel, electronic throttle and all the sensors. The horse power and torque is amazing.
After comparing options this is what I ended up getting. It was cheaper than buying all the parts at Summit and it came tuned which to me was a big deal.
I haven't driven it yet but it sure sounds nasty.
