Junkman's Corvette Repair Classes - Open Enrollment Starts NOW! - Corvette Forum : DigitalCorvettes.com Corvette Forums
Go Back   Corvette Forum : DigitalCorvettes.com Corvette Forums > C5 Corvette Forums > C5 Corvette - General Discussion
C5 Corvette - General Discussion General | Technical | Performance | Aftermarket | Discussions
Old 07-26-2012, 02:11 AM   #1
Junkman2008
Junkman2008's Avatar
Member #71977
2001 Navy Blue Metallic Coupe
Ha! That would be the blind leading the blind!
So here's the deal. I was rolling around in the Vette, chasing the honeys when my steering started to stiffing up. I immediately jumped out of the car and checked my power steering fluid level. That sucker was bone dry. So I limped the car to Auto Zone and filled the reservoir back to the correct level. I took off and saw this hottie who looked like she needed a ride. I scooped her up and about a mile later, the steering went stiff again. I dropped that honey off and took off back to a gas station. Upon checking the level again, I saw that it was bone dry, AGAIN!
So I put some more fluid in and raced home. Obviously I had a bad leak since it wasn't staying in the car more than a mile. Once I got the car inside the garage, this was what I saw. The three streams happened because I backed into the garage, pulled out and backed in again. This picture was taken a few days later.
After seeing that, I realized how bad the leak was. I did a quick check of the easy to get to hoses just in case the leak was a simple fix. No dice, so I turn off the lights and go in the house. I didn't bother to check under the car for the leak right then because I knew that I would have a good little puddle on the floor in the morning. Sure enough, after checking the next morning, I saw that I had fluid dripping off the bottom of the high pressure hose and landing dead center of that big puddle on the garage floor. That didn't tell me if it was the hose or the pump but it did limit me to assuming that it was one or the other.
So into the house I go to start ordering parts. I started ordering parts because I had just replaced the power steering pump and high pressure hose about 4 months ago. Everything was under warranty and I knew that one of those parts was going to be the culprit. Since it wasn't going to cost me anything, I decided to replace both just to be on the safe side. After all, I didn't think that I would be able to definitively locate the problem. How wrong I was!
I started taking everything apart. Didn't even need the service manual this time (it's scary that I learned so much from that head gasket job). One thing that I thought to do was to check and see if the hose was loose. It didn't appear to be loose so I took the pump and hose off the car. That's where the surprise happened.
As I went to remove the high pressure hose from the steering gear, I noticed that it was loose! I then checked the other end and realized that it was loose too! So now I'm thinking, all I have to do is tighten everything back up and cancel my orders. However, being as thorough as I am, I decided to take everything apart and give it a good eyeballing. It's a good thing that I did. Check this out.
The high pressure hose has a O-ring on both ends. The instructions are very specific that you install these O-rings. As small as the are, it's kinds hard to fathom that they do much but let m tell you, they do a ton. Check out my cable:
That little O-ring was missing from where the leak originated. When I checked the pump, this is what I found.
That little O-ring had disintegrated, probably from the hose being loose. How it got loose I have no clue. The hose doesn't move so I guess it loosened with the vibration of the car. I know that sucker won't get loose this time because I will ensure that it is torqued correctly. I just need to find a box end torque wrench. Is there such a animal?
The key here is that had I been lazy and just tightened up that hose, I would have still been leaking major fluid after putting everything back together. That would have sucked! The hose is in such an awkward location that taking it apart from the pump was almost out of the question. Now a O-ring probably would have fixed my problem but hell, why chance it? Taking that power steering pulley off the pump is enough of a reason for me to replace everything. That pulley is a bitch to get on and off, but at least I didn't destroy mine like I have seen quite a few people do.
So that's what's going on in the Junkman's garage... other than the usual going on's.
I promise not to make this another 8 month repair!
Junkman2008 is offline   Reply w/quote Quick reply to this message
The Following User Says Thank You to Junkman2008 For This Useful Post:
Shaggyvette (11-17-2017)
Old 07-26-2012, 03:18 AM   #2
rlphvac
Member #68962
81 C3
you can add a crowfoot end to the torque wrench I think but there is some sort of correction factor for proper torque & why in the hell dont you pick up one of them honeys thats a mechanic? I can see it now Junkman spotted cruising local technecial schools
rlphvac is offline   Reply w/quote Quick reply to this message
Old 07-26-2012, 03:40 AM   #3
Junkman2008
Member #71977
Originally Posted by rlphvac View Post
... why in the hell dont you pick up one of them honeys thats a mechanic? I can see it now Junkman spotted cruising local technecial schools
Novel idea!
Old 07-26-2012, 05:23 AM   #4
gmjunkie
gmjunkie's Avatar
Member #33628
78 L82 Cp.,03 Z51 6Sp. Cp.
Trade you jobs!~!!!
gmjunkie is offline   Reply w/quote Quick reply to this message
junk!!"Let your plans be murky and confused in daylight, and when you move, fall like a wet turd." - Sonny Toefoo
Old 07-26-2012, 05:58 AM   #5
Poncherello
Grey Squirrel
Poncherello's Avatar
Member #5040
Looking
Time to sell that car
Poncherello is offline   Reply w/quote Quick reply to this message
Ain't THAT the mofo truth
Old 07-26-2012, 07:24 AM   #6
walleyfisher
walleyfisher's Avatar
Member #81755
1974 coupe & 1984 coupe
Looks like you need a higher gauge extension cord before you have a melt down
walleyfisher is offline   Reply w/quote Quick reply to this message
"If you're not on somebody's shit list, you're not doing anything worthwhile"
Old 07-26-2012, 08:27 AM   #7
Junkman2008
Member #71977
Originally Posted by gmjunkie View Post
Trade you jobs!~!!!
So where's your thread? That's a writeup just waiting to happen!
Old 07-26-2012, 08:28 AM   #8
Junkman2008
Member #71977
Yea, I'm almost approaching your luck level with cars Ponch!
Old 07-26-2012, 08:29 AM   #9
Junkman2008
Member #71977
Nah, that cord is just powering my work light.
Old 07-26-2012, 08:41 AM   #10
Fly03Z06
Fly03Z06's Avatar
Member #68577
Now 03Z, Then 00, 80, 79
......and the saga continues
1. Get that car back together.
2. Put those legs, WW in the copilots seat and....
3. .....bring them up to the Mid-Ohio Corral and cheer on the Corvette Racing Team August 3rd & 4th.
4. Bring some Adams
5. We will compare leaky pictures ...no maggots, I promise
Fly03Z06 is offline   Reply w/quote Quick reply to this message
......nevermind
Old 07-26-2012, 09:56 AM   #11
Junkman2008
Member #71977
MAGGOTS!
Old 07-26-2012, 11:19 AM   #12
deanz02
Member #116949
2002 coupe
Hey Junkman, you probley know this but I'll offer it up anyway. When you put that new O-ring back in use an O-ring lube. Best lube I have found and always use is Syl-Glide. Should be able to get it at any good parts store. It comes in a squeeze tube and it's like a grease. I have tried many other lubes and nothing will work except o-ring lubes.
deanz02 is offline   Reply w/quote Quick reply to this message
Old 07-26-2012, 11:28 AM   #13
Junkman2008
Member #71977
Thanks for the advice. The instructions say to use clean power steering fluid but hey, I'll try something new.
Old 07-26-2012, 11:43 AM   #14
iburke
Sir Dude
iburke's Avatar
Member #6081
1971 T-Top
Why do you think I'm enrolled at the local technecial school.
iburke is offline   Reply w/quote Quick reply to this message
If life gets any better, I don't know if I can handle it.
Old 07-26-2012, 11:45 AM   #15
Junkman2008
Member #71977
I'm telling Wendy!!!
