New Spy Pics with a tad less cammo. Update in first post 3/31/18 - Corvette Forum : DigitalCorvettes.com Corvette Forums
Go Back   Corvette Forum : DigitalCorvettes.com Corvette Forums > C8 Corvette Forums > C8 Corvette
C8 Corvette General | Technical | Performance | Aftermarket | Discussions
Old 02-08-2018, 10:39 PM   #1
Longtimer
Longtimer's Avatar
Member #3668
'07 Z51 6Mn NCM delivery, '79 L82 4 sp gymk - Gone '87 Z52 4+3, 76 L-82 4 spd
Latest commentary & pics 3/31/18:
GM Authority reader Bob, who took the shots, managed to get up close to the models. He said that the mid-engine Vettes “sound fantastic”, as you can verify from the most recent video of the sports car undergoing testing.
It does seem odd that ole "Bob" got that close and did not get any interior shots or shots with the light shining through some of the mesh cammo. Maybe ole "Bob" is a GM controlled leaker. Oh well. Beggars cannot be choosers.
Video 3/28/18 (VERY short):
https://youtu.be/06Qypybf0u0
New pic 3/26/18:
Old pics:
Longtimer is online now   Reply w/quote Quick reply to this message
Corvette ownership is like owning your own fountain of youth ... and we get a sip from it each time the signal turns green.
Old 02-08-2018, 11:38 PM   #2
The Torch
The Torch's Avatar
Member #799
2004 Black/Mod Red-Z06
That's not camo. It's a winter coat to keep it from getting cold.
The Torch is offline   Reply w/quote Quick reply to this message
Old 02-09-2018, 09:42 AM   #3
Maniacmechanic1
Member #176497
I see Round Oval Taillights Lit up Braking .
What do You see Longtimer ?
Old 02-09-2018, 05:38 PM   #4
Longtimer
Longtimer's Avatar
Member #3668
I see a bunch of LED bulbs with no lenses that could end up being anything from round to C7-type t-lights. There is SO much they can do with lenses today, the possibilities are too vast to predict. Don't forget that the fascia t-light opening wraps around to the side, suggesting that the lens would also wrap to the side. Could the lens shapes under the surface make 4 round lights? Sure....or not
Old 03-27-2018, 01:17 AM   #5
Longtimer
Longtimer's Avatar
Member #3668
Ttt
Old 03-28-2018, 10:31 AM   #6
stinger430
stinger430's Avatar
Member #8212
Thanks LT!!!
Looks like a similar front end to the C7 ZR1. Tail lights might be similar to C7 if that's the case, along with the rest of the styling cues.
stinger430 is online now   Reply w/quote Quick reply to this message
Old 03-28-2018, 11:25 AM   #7
Poncherello
Grey Squirrel
Poncherello's Avatar
Member #5040
Looking
I don't like the stance of that at all.....or the Camaro tail lights
Poncherello is offline   Reply w/quote Quick reply to this message
Ain't THAT the mofo truth
Old 03-28-2018, 04:28 PM   #8
Longtimer
Longtimer's Avatar
Member #3668
Originally Posted by stinger430 View Post
Thanks LT!!!
Taillights look more like current Camaro taillights, but shorter in height and folded/creased horizontally and wrapped to the side of the car.
Old 03-28-2018, 05:30 PM   #9
stinger430
stinger430's Avatar
Member #8212
Ha Ha...so once again the Camaro is leading the way in styling? Well I guess GM knows what they're doing.
Old 03-29-2018, 10:07 PM   #10
Longtimer
Longtimer's Avatar
Member #3668
The Red circle clearly shows the turbos are NOT in the V like the Cadillac DOHC. That does not exclude the possibility of using some common parts - not heads of course, but maybe much of the bottom end?
The yellow lines show the shape of the taillights.
Old 04-01-2018, 07:34 PM   #11
Maniacmechanic1
Member #176497
LOL Longtimer.
I know Corvette exclusive Tail Lights are real important to You.
Old 04-01-2018, 07:38 PM   #12
Maniacmechanic1
Member #176497
Try & Find out who is supplying the Twin Turbos for the C8 Longtimer.
Ceramic Ball Bearing equipped or Not.
Ceramic Ball Bearings are the Best.
Borg Warner Turbos.
Garrett Turbos.
Definite do not want china ebay turbos.
Old 04-01-2018, 08:38 PM   #13
Longtimer
Longtimer's Avatar
Member #3668
I'll keep my eyes peeled but doubt if we'll get that level of information before the C8 reveal. There's no guarantee that the Cadillac DOHC TT V6 engineering will be applied to the C8 DOHC TT V8, but I think it is safe to say that the Vette's turbos will not be any lower quality than the Cad V6 application.
The Cad TT V6 uses two Garrett turbos mounted low and outside of the engine. Cad describes them as "...low-inertia turbochargers’ featherweight titanium-aluminide turbines used with vacuum-actuated wastegate control for precise, responsive torque production. The titanium-aluminide turbines reduce rotating inertial load by more than 50 percent, compared with conventional Inconel turbine wheels. That means less exhaust energy – which spins the turbines – is wasted in stored inertial loads.
In practical terms, that means the relatively small size of the turbochargers and their lightweight turbines foster more immediate “spooling,” which practically eliminates lag, for an immediate feeling of power delivery. They produce up to 18 pounds of boost (125 kPa)."
We don't have this level of info on the "V" mounted turbos in the upcoming Cad TT V8.
Old 04-01-2018, 08:50 PM   #14
Maniacmechanic1
Member #176497
Its High Temperature Titanium alloy.
Similar to 6AL4V but much better.
True Aerospace Titanium alloy on the Hot side Turbine.
Manley Calls it High Temp Orange Titanium on their premium Race Ti valves.
Old 04-01-2018, 08:53 PM   #15
Maniacmechanic1
Member #176497
Inconel still takes High temps better 1600F + .
Probably maxed out safe the Caddy TT engine with Turbos supplied.
