1999 Corvette diagnostic codes and descriptions - Corvette Forum : DigitalCorvettes.com Corvette Forums
Go Back   Corvette Forum : DigitalCorvettes.com Corvette Forums > C5 Corvette Forums > C5 Corvette - Technical | Performance | Aftermarket
C5 Corvette - Technical | Performance | Aftermarket Technical | Performance | Aftermarket | Discussions
Closed Thread
Old 10-22-2005, 11:22 PM   #1
moore_rb
moore_rb's Avatar
Member #1975
64 hardtop restomod
Click here to learn how to retrieve the Diagnostic codes on your C5 Corvette:
https://www.digitalcorvettes.com/foru...018#post504018
Below are the Diagnostic codes for 1999 cars:
1016 Loss Of PCM Communications
1064 Loss Of BCM Serial Data Communication
1096 Loss Of IPC Communications
1255 Generic Loss Of Communications
B0016 RF/Passenger Frontal Deployment Loop (Single Stage or Stage 1) Resistance Low
B0017 RF/Passenger Frontal Deployment Loop (Single Stage or Stage 1) Open
B0018 RF/Passenger Frontal Deployment Loop (Single Stage or Stage 1) Short to Ground/Voltage Out of Range
B0022 LF/Driver Frontal Deployment Loop (Single Stage or Stage 1) Resistance Low
B0024 LF/Driver Frontal Deployment Loop (Single Stage or Stage 1) Short to Ground/Voltage Out of Range
B0026 LF/Driver Frontal Deployment Loop (Single Stage or Stage 1) Open
B0051 Deployment Commanded
B0053 Deployment Commanded with Loop Malfunctions Present
B0332 Outside Air Temp Sensor Short to Ground
B0333 Outside Air Temperature Sensor Open
B0337 Inside Air Temp Sensor Short to GND
B0338 Inside Air Temperature Sensor Open
B0348 Sunload Temperature Sensor Open
B0361 Left Actuator Feedback Short to GND
B0363 Left Actuator Feedback Open
B0365 Right Actuator Feedback Short to GND
B0367 Right Actuator Feedback Open
B0432 Rear Defogger Relay Circuit
B0433 Rear Defogger Relay Circuit
B0441 Left Actuator Out of Range
B0446 Right Actuator Out of Range
B0502 RH DRL Relay Circuit
B0503 RH DRL Relay Circuit
B0507 LH DRL Relay Circuit
B0508 LH DRL Relay Circuit
B0516 Speedometer Signal Circuit Malfunction
B0521 Tachometer Signal Circuit Malfunction
B0605 BCM Internal Memory Malfunction
B0605 Receiver Internal Memory Malfunction
B0846 Battery 2 Out of Range
B0851 Battery 1 Out of Range
B0856 +5 Volt Reference Out of Range
B1000 ECU Malfunction
B1001 Option Configuration Error
B1512 DIC Switch 1 Signal Short to Ground
B1517 DIC Switch 2 Signal Short to Ground
B1522 DIC Switch 3 Signal Short to Ground
B1527 DIC Switch 4 Signal Short to Ground
B1532 DIC Switch 5 Signal Short to Ground
B1537 DIC Switch 6 Signal Short to Ground
B1542 Oil Temperature Circuit Short to Ground
B1543 Oil Temperature Circuit Open
B2002 Fore/Aft Seat Motor Open or Short to GND
B2007 Front Vert. Seat Motor Open or Shorted
B2012 Rear Vert. Seat Motor Open or Shorted
B2172 Seat Front Up Switch Shorted to Ground
B2177 Seat Front Down Switch Shorted to Ground
B2182 Seat Rear Up Switch Shorted to Ground
B2187 Seat Rear Down Switch Shorted to Ground
B2192 Seat Forward Switch Shorted to Ground
B2197 Seat Reverse Switch Shorted to Ground
B2202 Left Window Up Switch Circuit
B2203 Right Window Up Switch Circuit
B2204 Left Window Down Switch Circuit
B2205 Right Window Down Switch Circuit
B2206 Right Window Up Switch Circuit
B2208 Right Window Down Switch Circuit
B2222 LT Mirror Select Switch Circuit
B2224 RT Mirror Select Switch Circuit
B2226 Mirror Right Switch Circuit
B2228 Mirror Left Switch Circuit
B2232 Mirror Up Switch Circuit
B2234 Mirror Down Switch Circuit
B2236 Left Door Lock Switch Circuit
B2237 Right Door Lock Switch Circuit
B2238 Left Door Unlock Switch Circuit
B2239 Right Door Unlock Switch Circuit
B2242 Memory 1 Switch Circuit
B2244 Memory 2 Switch Circuit
B2252 Key Cylinder Switch Circuit
B2253 Key Cylinder Switch Circuit
B2262 Horizontal Position Sensor Circuit
B2263 Horizontal Position Sensor Circuit
B2264 Vertical Position Sensor Circuit
B2265 Vertical Position Sensor Circuit
B2272 Left Mirror Motor Circuit
B2273 Right Mirror Motor Circuit
B2274 Window Motor Circuit
B2275 Window Motor Circuit
B2276 Door Lock Motor/Mirror Heater Circuit
B2277 Door Lock Motor/Mirror Heater Circuit
B2278 Switch Indicator/Illum Circuit
B2279 Switch Illumination Circuit
B2282 Battery #1 Circuit
B2283 Battery #1 Circuit
B2284 Battery #2 Circuit
B2285 Battery #2 Circuit
B2286 LH Mirror Supply Circuit
B2287 RH Mirror Supply Circuit
B2403 Front Fog Lamp Switch Circuit
B2408 Rear Fog Lamp Switch Circuit
B2482 Backup Lamp Relay Circuit
B2483 Backup Lamp Relay Circuit
B2527 Horn Relay Circuit
B2528 Horn Relay Circuit
B2567 Folding Top Release Switch Circuit
B2573 Hatch Release Switch Circuit
B2578 Right Front Turn Signal Monitor Circuit
B2583 Left Front Turn Signal Monitor Circuit
B2587 Column Lock/Unlock Drive A
B2588 Column Lock/Unlock Drive A
B2592 Column Lock/Unlock Drive B
B2593 Column Lock/Unlock Drive B
B2597 Traction Control System Switch Circuit
B2600 Seat Motor to Battery Voltage
B2605 Seat Front Vert. Position Sensor Failure
B2606 Seat Rear Vert. Position Sensor Failure
B2607 Seat Horizontal Position Sensor Failure
B2647 Ambient Light Sensor Circuit Low
B2648 Ambient Light Sensor Circuit High
B2721 PASS-Key Detection Circuit
B2722 PASS-Key Detection Circuit
B2723 PASS-Key Detection Circuit
B2735 PASS-Key Programming Mode Active
B2805 No Transmitters Programmed
B2852 Telescoping Column In Switch Shorted to Ground
B2857 Telescoping Column Out Switch Shorted to Ground
B2860 Telescoping Column Position Sensor Failure
C1214 Solenoid Valve Relay Contact or Coil Circuit Open
C1217 Pump Motor Relay Contact Circuit Open
C1221 LF Wheel Speed Sensor Input Signal is 0
C1222 RF Wheel Speed Sensor Input Signal is 0
C1223 LR Wheel Speed Sensor Input Signal is 0
C1224 RR Wheel Speed Sensor Input Signal is 0
C1225 LF Excessive Wheel Speed Variation
C1226 RF Excessive Wheel Speed Variation
C1227 LR Excessive Wheel Speed Variation
C1228 RR Excessive Wheel Speed Variation
C1232 LF Wheel Speed Circuit Open or Shorted
C1233 RF Wheel Speed Circuit Open or Shorted
C1234 LR Wheel Speed Circuit Open or Shorted
C1235 RR Wheel Speed Circuit Open or Shorted
C1236 Low System Supply Voltage
C1237 High System Supply Voltage
C1241 MAGNA STEER Circuit Malfunction
C1241 Magnasteer Malfunction
C1242 BPMV Pump Motor Ground Circuit Open
C1243 BPMV Pump Motor Stalled
C1245 Brake Sensor Pressure Always High
C1247 Brake Pressure Differential Switch Activated
C1255 EBTCM Internal Malfunction
C1256 EBCM Internal Malfunction
C1261 LF Inlet Valve Solenoid Malfunction
C1262 LF Outlet Valve Solenoid Malfunction
C1263 RF Inlet Valve Solenoid Malfunction
C1264 RF Outlet Valve Solenoid Malfunction
C1265 LR Inlet Valve Solenoid Malfunction
C1266 LR Outlet Valve Solenoid Malfunction
C1267 RR Inlet Valve Solenoid Malfunction
C1268 RR Outlet Valve Solenoid Malfunction
C1271 LF TCS Master Cylinder Isolation Valve Malfunction
C1272 LF TCS Prime Valve Malfunction
C1273 RF TCS Master Cylinder Isolation Valve Malfunction
C1274 RF TCS Prime Valve Malfunction
C1276 Delivered Torque Signal Circuit Malfunction
C1277 Requested Torque Signal Circuit Malfunction
C1278 TCS Temporarily Inhibited By PCM
C1281 Steering Sensor Uncorrelated Malfunction
C1282 Yaw Rate Sensor Bias Circuit Malfunction
C1283 Excessive Time to Center Steering
C1284 Lateral Accelerometer Sensor Self Test Malfunction
C1285 Lateral Accelerometer Sensor Circuit Malfunction
C1286 Steering Sensor Bias Malfunction
C1286 Steering/Lateral Accelerometer Sensor Bias Malfunction
C1287 Steering Sensor Rate Malfunction
C1288 Steering Sensor Circuit Malfunction
C1291 Open Brake Lamp Switch Contacts During Deceleration
C1293 DTC C1291/C1292 Set in Current or Previous Ignition Cycle
C1294 Brake Lamp Switch Circuit Always Active
C1295 Brake Lamp Switch Circuit Open
C1296 Master Cylinder Sensor Circuit Open or Shorted
C1650 ESC Module Malfunction
C1658 EEPROM Calibration Malfunction
C1710 LF Shock Absorber Solenoid Circuit
C1711 LF Shock Absorber Solenoid Circuit
C1712 LF Shock Absorber Solenoid Circuit
C1715 RF Shock Absorber Solenoid Circuit
C1716 RF Shock Absorber Solenoid Circuit
C1717 RF Shock Absorber Solenoid Circuit
C1720 LR Shock Absorber Solenoid Circuit
C1721 LR Shock Absorber Solenoid Circuit
C1722 LR Shock Absorber Solenoid Circuit
C1725 RR Shock Absorber Solenoid Circuit
C1726 RR Shock Absorber Solenoid Circuit
C1727 RR Shock Absorber Solenoid Circuit
C1743 Loss of Vehicle Speed Signal
C1744 Loss of Chassis Pitch Input
C1760 LF Position Sensor
C1761 RF Position Sensor
C1762 LR Position Sensor
C1763 RR Position Sensor
C1768 Position Sensor Supply Malfunction
C1780 Loss of Steering Position Signal
C1786 RTD Relay Malfunction
C1787 RTD Relay Circuit
C1788 RTD Relay Circuit
C1790 Ride Control Switch
C1791 Ride Control Switch
C2100 Left Front TPM Sensor Malfunction
C2105 Right Front TPM Sensor Malfunction
C2110 Right Rear TPM Sensor Malfunction
C2115 Left Rear TPM Sensor Malfunction
C2120 TPM System Malfunction
C2121 TPM System Programming Malfunction
P0101 Mass Air Flow (MAF) Sensor Performance
P0102 Mass Air Flow (MAF) Sensor Circuit Low Frequency
P0103 Mass Air Flow (MAF) Sensor Circuit High Frequency
P0107 Manifold Absolute Pressure (MAP) Sensor Circuit Low Voltage
P0108 Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage
P0112 Intake Air Temperature (IAT) Sensor Circuit Low Voltage
P0113 Intake Air Temperature (IAT) Sensor Circuit High Voltage
P0117 Engine Coolant Temperature (ECT) Sensor Circuit Low Voltage
P0118 Engine Coolant Temperature (ECT) Sensor Circuit High Voltage
P0125 Engine Coolant Temperature (ECT) Insufficient for Closed Loop Fuel Control
P0131 HO2S Circuit Low Voltage Bank 1 Sensor 1
P0132 HO2S Circuit High Voltage Bank 1 Sensor 1
P0133 HO2S Slow Response Bank 1 Sensor 1
P0134 HO2S Circuit Insufficient Activity Bank 1 Sensor 1
P0135 HO2S Heater Performance Bank 1 Sensor 1
P0137 HO2S Circuit Low Voltage Bank 1 Sensor 2
P0138 HO2S Circuit High Voltage Bank 1 Sensor 2
P0140 HO2S Circuit Insufficient Activity Bank 1 Sensor 2
P0141 HO2S Heater Performance Bank 1 Sensor 2
P0151 HO2S Circuit Low Voltage Bank 2 Sensor 1
P0152 HO2S Circuit High Voltage Bank 2 Sensor 1
P0153 HO2S Slow Response Bank 2 Sensor 1
P0154 HO2S Circuit Insufficient Activity Bank 2 Sensor 1
P0155 HO2S Heater Performance Bank 2 Sensor 1
P0157 HO2S Circuit Low Voltage Bank 2 Sensor 2
P0158 HO2S Circuit High Voltage Bank 2 Sensor 2
P0160 HO2S Circuit Insufficient Activity Bank 2 Sensor 2
P0161 HO2S Heater Performance Bank 2 Sensor 2
P0171 Fuel Trim System Lean Bank 1
P0172 Fuel Trim System Rich Bank 1
P0174 Fuel Trim System Lean Bank 2
P0175 Fuel Trim System Rich Bank 2
P0200 Injector Control Circuit
P0218 Transmission Fluid Overtemperature
P0230 Fuel Pump Relay Control Circuit
P0300 Engine Misfire Detected
P0325 Knock Sensor Module Performance
P0327 Knock Sensor (KS) 1 Circuit
P0332 Knock Sensor (KS) 2 Circuit
P0335 Crankshaft Position (CKP) Sensor Circuit
P0336 Crankshaft Position (CKP) Sensor Performance
P0341 Camshaft Position (CMP) Sensor Performance
P0342 Camshaft Position (CMP) Sensor Circuit Low Voltage
P0343 Camshaft Position (CMP) Sensor Circuit High Voltage
P0351 Ignition Coil 1 Control Circuit
P0352 Ignition Coil 2 Control Circuit
P0353 Ignition Coil 3 Control Circuit
P0354 Ignition Coil 4 Control Circuit
P0355 Ignition Coil 5 Control Circuit
P0356 Ignition Coil 6 Control Circuit
P0357 Ignition Coil 7 Control Circuit
P0358 Ignition Coil 8 Control Circuit
P0410 Secondary Air Injection (AIR) System
P0412 Secondary Air Injection (AIR) Solenoid Relay Control Circuit
P0418 Secondary Air Injection (AIR) Pump Relay Control Circuit
P0420 Catalyst System Low Efficiency Bank 1
P0430 Catalyst System Low Efficiency Bank 2
P0440 Evaporative Emission (EVAP) System
P0442 Evaporative Emission (EVAP) System Small Leak Detected
P0443 Evaporative Emission (EVAP) Purge Solenoid Control Circuit
P0446 Evaporative Emission (EVAP) Vent System Performance
P0449 Evaporative Emission (EVAP) Vent Solenoid Control Circuit
P0452 Fuel Tank Pressure Sensor Circuit Low Voltage
P0453 Fuel Tank Pressure Sensor Circuit High Voltage
P0461 Fuel Level Sensor Performance
P0462 Fuel Level Sensor Circuit Low Voltage
P0463 Fuel Level Sensor Circuit High Voltage
P0480 Cooling Fan Relay 1 Control Circuit
P0481 Cooling Fan Relay 2 and 3 Control Circuit
P0500 Vehicle Speed Sensor (VSS) Circuit
P0502 Vehicle Speed Sensor (VSS) Circuit Low Input
P0503 Vehicle Speed Sensor (VSS) Circuit Intermittent
P0506 Idle Speed Low
P0507 Idle Speed High
P0522 Engine Oil Pressure (EOP) Sensor Circuit Low Voltage
P0523 Engine Oil Pressure (EOP) Sensor Circuit High Voltage
P0530 Air Conditioning (A/C) Refrigerant Pressure Sensor Circuit
P0562 System Voltage Low
P0563 System Voltage High
P0567 Cruise Control Resume Switch Circuit
P0568 Cruise Control Set Switch Circuit
P0571 Cruise Control Brake Switch Circuit
P0601Control Module Read Only Memory (ROM)
P0602 Control Module Not Programmed
P0604 Control Module Random Access Memory (RAM)
P0606 Control Module Internal Performance
P0608 Vehicle Speed Output Circuit
P0645 Air Conditioning (A/C) Clutch Relay Control Circuit
P0650 Malfunction Indicator Lamp (MIL) Control Circuit
P0654 Engine Speed Output Circuit
P0704 Clutch Switch Circuit
P0705 Trans Range Switch Circuit
P0706 Trans Range Switch Performance
P0711 TFT Sensor Circuit Range/Performance
P0712 Transmission Fluid Temperature (TFT) Sensor Circuit Low Input
P0713 Transmission Fluid Temperature (TFT) Sensor Circuit High Input
P0719 Brake Switch Circuit Low Input
P0724 Brake Switch Circuit High Input
P0740 TCC Enable Solenoid Circuit Electrical
P0742 TCC System Stuck On
P0748 Pressure Control Solenoid Circuit Electrical
P0751 1-2 Shift Solenoid Valve Performance
P0753 1-2 Shift Solenoid Circuit Electrical
P0756 2-3 Shift Solenoid Valve Performance
P0758 2-3 Shift Solenoid Circuit Electrical
P0785 3-2 Shift Solenoid Circuit Electrical
P0801 Reverse Inhibit Solenoid Control Circuit
P0803 Skip Shift Solenoid Control Circuit
P0804 Skip Shift Lamp Control Circuit
P1111 Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage
P1112 Intake Air Temperature (IAT) Sensor Circuit Intermittent Low Voltage
P1114 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent Low Voltage
P1115 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent High Voltage
P1120 Throttle Position (TP) Sensor 1 Circuit
P1125 Accelerator Pedal Position (APP) System
P1133 HO2S Insufficient Switching Bank 1 Sensor 1
P1134 HO2S Transition Time Ratio Bank 1 Sensor 1
P1153 HO2S Insufficient Switching Bank 2 Sensor 1
P1154 HO2S Transition Time Ratio Bank 2 Sensor 1
P1220 Throttle Position (TP) Sensor 2 Circuit
P1221 Throttle Position (TP) Sensor 1- 2 Correlation
P1258 Engine Coolant Overtemperature - Protection Mode Active
P1275 Accelerator Pedal Position (APP) Sensor 1 Circuit
P1276 Accelerator Pedal Position (APP) Sensor 1 Performance
P1280 Accelerator Pedal Position (APP) Sensor 2 Circuit
P1281 Accelerator Pedal Position (APP) Sensor 2 Performance
P1285 Accelerator Pedal Position (APP) Sensor 3 Circuit
P1286 Accelerator Pedal Position (APP) Sensor 3 Performance
P1380 Misfire Detected - Rough Road Data Not Available
P1381 Misfire Detected - No Communication with Brake Control Module
P1415 Secondary Air Injection (AIR) System Bank 1
P1416 Secondary Air Injection (AIR) System Bank 2
P1431 Fuel Level Sensor 2 Performance
P1432 Fuel Level Sensor 2 Circuit Low Voltage
P1433 Fuel Level Sensor 2 Circuit High Voltage
P1441 Evaporative Emission (EVAP) System Flow During Non-Purge
P1514 Throttle Body Performance
P1515 Control Module Throttle Actuator Position Performance
P1516 Throttle Actuator Control (TAC) Module Throttle Actuator Position Performance
P1517 Throttle Actuator Control (TAC) Module Performance
P1518 Throttle Actuator Control (TAC) Module Serial Data Circuit
P1539 Air Conditioning (A/C) Clutch Feedback Circuit High Voltage
P1546 Air Conditioning (A/C) Clutch Feedback Circuit Low Voltage
P1571 Traction Control Torque Request Circuit
P1574 Stoplamp Switch Circuit
P1575 Extended Travel Brake Switch Circuit
P1626 Theft Deterrent Fuel Enable Signal Lost
P1630 Theft Deterrent Learn Mode Active
P1631 Theft Deterrent Start Enable Signal Not Correct
P1635 5 Volt Reference 1 Circuit
P1637 Generator L-Terminal Circuit
P1638 Generator F-Terminal Circuit
P1639 5 Volt Reference 2 Circuit
P1652 Powertrain Induced Chassis Pitch Output Circuit
P1689 Traction Control Delivered Torque Output Circuit
P1810 TFP Valve Position Switch Circuit
P1860 TCC PWM Solenoid Circuit Electrical
P1870 Transmission Component Slipping
U1000 Loss of Communications
U1016 Loss of Communications with PCM
U1040 Loss of Communications with TCS
U1056 Loss of Communications with RTD
U1064 Loss of Communications with BCM
U1088 Loss of Communications with SDM
U1096 Loss of Communications with IPC
U1128 Loss of Communications with RADIO
U1153 Loss of Communications with HVAC
U1160 Loss of Communications with LDCM
U1161 Loss of Communications with RDCM
U1166 Loss of Communications with SCM
U1176 Loss of Communications with RFA
U1255 Serial Data Line Malfunction
U1300 Serial Data Line Short to Ground
U1301 Serial Data Line Short to Voltage
moore_rb is offline   Quick reply to this message
The reason some people get lost in thought is because it's unfamiliar territory....
-Paul Fix.
Closed Thread
