Computer Geeks, Step On In - Junkman's Monster PC Rebuild! - Corvette Forum : DigitalCorvettes.com Corvette Forums
Old 01-20-2009, 08:42 AM   #1
Junkman2008
Junkman2008's Avatar
Member #71977
2001 Navy Blue Metallic Coupe
Well, after the fan on my chipset quit working (like they always do) and started causing me to have blue screens, I decided it was time for an upgrade. Not a total rebuild as most of my stuff was somewhat new but the motherboard, CPU and RAM had to go. So after fooling with it for a week or so, I finally have her up and running. The hardest part of the whole process was routing all of the freaking wires.
Here it is in pictures:
First off, the motherboard had to go (Biostar TF570). It was a nice board when new, with SLI PCI Express for some serious gaming, which I really never got around to doing seriously.
I decided to stay with my HD TV tuner card. It produces some outstanding HD video.
Although this card is older, it still has more than enough ponies to play anything out there. No need to change out here!
Here's the motherboard that is going in (DFI UT X48-T2R LanParty). This puppy supports up to 8Gb of DDR2/3 800Mhz RAM. It delivers up to 21Gb/s bandwidth at 1333Mhz! That's server grade my friends! Not to mention the quad core processors it supports. There's also the 8 SATA drives (2 at 1000RPM's), the 3 PCI Express slots and the Transpiper cooling system. I won't go into a lot of detail. That might put the non-geeks to sleep.
The backside, showing off the 6 USB, 1 firewire port, 1 10/100 LAN port and 1 Gb LAN port. It also supports 2 more USB to the front of the box as well as another firewire port. In all, it supports 12 USB devices!
Here's the processor that I'm putting in. It's not the fastest made today, but everyone knows you never buy the fastest out. That's like buying a new car. You eat a ton of depreciation as soon as you walk out the door. If you know what you are looking at, you can see that this a Quad Core processor at 2.83Ghz per core, with each core having a 12Mb cache!
Processor mounted!
Cooling fan in place...
Check out this part of the cooling system. It runs out the back of the computer and one of the system fans keep it cool. This is the coldest running system that I have ever built. Right now it is running at 41 degrees Celsius. That's cooooool!
One of the big ol' system fans (5").
All this hardware will not run unless you put some horsepower behind it. Antec is one of the best in the business. This True Power Trio has 3 rails. That's like 3 power supplies in one. I've only managed to toast 1 of these in 10 years and that was because I was running all of the hard drives on one rail. What was I thinking?
This was the part I was not looking forward to. This mess of wires was a bear to organize, keeping air flow throughout the case in mind.
However, the PC Surgeon will not be denied! In this shot, you can see 3 of my 500Gb hard drives. There's two more in removable bays a little higher up and a external also. That's 3 terabytes of storage because I be a video cruncher!
A shot of the back of the case. The board comes with the Bernstein Audio HD card but I'm partial to my ol' Audigy 2. That front access panel is to die for. I always hated pulling out the computer just to plug something in the back.
A shot of the front of the case. It's a Cooler Master case with brushed aluminum and smoked Plexiglas. This is why I always build my own computers. You can't get cool stuff like this from Dell or Best Buy. Plus, I didn't have to replace everything when I upgraded because I always use quality parts. Those parts move along when I upgrade unless they are no longer useful or if something else significantly better comes out.
Basically, what you are looking at from top to bottom is:
1 IDE removable bay
1 DVD/CD burner
1 SATA removable bay
Audigy 2 front panel
Another DVD/CD burner
Card reader/floppy drive.
There's 6Gb of RAM installed with all that hard drive space I mentioned above. I could have gotten some engine mod's for the Vette with what all this stuff cost but my computer will pay for itself in a few weeks. That's why I throw stupid money at it. Also, slow computers and slow cars I do not do!
Well, that was your daily dosage of computer geekdom. Put your pocket protectors up and go about you daily choirs. Remember though, geeks are in!
Junkman2008 is offline   Reply w/quote Quick reply to this message
Old 01-20-2009, 08:47 AM   #2
Vette_Newb
Account Disabled.
Vette_Newb's Avatar
Member #6180
1989 L98 Coupe
Sweet, you should do some case mods and add some lighting.
Vette_Newb is offline   Reply w/quote Quick reply to this message
Old 01-20-2009, 08:51 AM   #3
Junkman2008
Member #71977
The cubby hole that it sits in would hide all the lighting so that would be useless for me. Besides, I don't have much room for anything else. I got over the lighting stage shortly after it started. Plus, I don't want to suck any more power out of that power supply!
Old 01-20-2009, 08:59 AM   #4
Tsavo85
No Kitty, my Pot Pie!
Tsavo85's Avatar
Member #64308
'85 4+3
You impress the hell out of me. I wish I could do something like this, but i am just happy to keep my machine running!
Tsavo85 is offline   Reply w/quote Quick reply to this message
-Kyle
"Pizzas are a lot like strippers. The longer they spin, the hotter & greasier they get, making fat college guys want them even more."
Old 01-20-2009, 09:09 AM   #5
Junkman2008
Member #71977
Trust me, I was there too back in the early 90's. I didn't even plan on doing what I do for a living. I just wanted to be able to play this little shooter game called Quake, but my 386Dx-2 with 4Mb of RAM wouldn't play. Someone said I needed to upgrade.
...and down that road I went, never to return back to common sense. That's why I understand guys who mod their Vettes but I won't be making THAT trip!
Old 01-20-2009, 09:19 AM   #6
iburke
Sir Dude
iburke's Avatar
Member #6081
1971 T-Top
I will have to post a picture of my computer. every one will get a good laugh...I solved the cooling problem I just took the case off and laid every thing out on the desk.
Nice looking computer bro want to trade...
iburke is offline   Reply w/quote Quick reply to this message
If life gets any better, I don't know if I can handle it.
Old 01-20-2009, 09:31 AM   #7
Junkman2008
Member #71977
You sound like some of the guys at LAN parties I've seen. They show up with Pratt & Whitney sized fans and ice blocks trying to keep their computers from crashing!
Old 01-20-2009, 09:55 AM   #8
Blk50thVette
Blk50thVette's Avatar
Member #63365
Sold
Haha damn Jman. I spent $2,600 back in early 06 when I got back from the sand box. Never have had that thing running right. My brother is the computer geek in my family.. he'll get it running then it'll crash again in a few months and not work. For that matter, neither of my computers at home work right now. Amazingly my work laptop, which nobody else touches never crashes.
Blk50thVette is offline   Reply w/quote Quick reply to this message
Hail to the Infantry!
Old 01-20-2009, 10:10 AM   #9
Junkman2008
Member #71977
Move closer. I'll have your PC's singing in harmony like the Delphonics!
Old 01-20-2009, 10:13 AM   #10
Larry D1000
Larry D1000's Avatar
Member #56708
'05 C6 *sold*
Very nice job JM. Think you could build me a superbad gaming pc too???
Larry D1000 is offline   Reply w/quote Quick reply to this message
"Democracy is two wolves and a lamb deciding what to have for dinner. Liberty is a well-armed lamb." - Benjamin Franklin
Old 01-20-2009, 10:15 AM   #11
Blk50thVette
Member #63365
Sold
Haha, believe you me if I could find work that paid the same out where cost of living was significantly cheaper I'd have been there already. Instead I live in yuppieville northern va. I vote for my company transfering their contracts department to our alabama office..
Old 01-20-2009, 10:29 AM   #12
Junkman2008
Member #71977
Tell me how many satellites you want to control and I'll build it. If the FBI shows up at your house, I don't know you.
Old 01-20-2009, 12:36 PM   #13
Vette_Newb
Account Disabled.
Vette_Newb's Avatar
Member #6180
1989 L98 Coupe
No shit. Everything pinned to cardboard with fans and ice packs...
Old 01-20-2009, 03:00 PM   #14
Fluffy
Fluffy's Avatar
Member #68058
JSB 2008 Coupe
You didn't put your drives in RAID?
a++ Cedric
Fluffy is offline   Reply w/quote Quick reply to this message
Rayman XIII
Old 01-20-2009, 03:20 PM   #15
Junkman2008
Member #71977
a++ Cedric
Heck no. I deal enough with RAID configuration in the field. I'm smart enough to do backups of all my data so that if a drive fails, it's no biggie.
