examing failed rod bolts - Corvette Forum : DigitalCorvettes.com Corvette Forums
Go Back   Corvette Forum : DigitalCorvettes.com Corvette Forums > General Corvette Topics > General Automotive & Shop
General Automotive & Shop Non-gen specific technical discussion. Automotive tools, techniques and know-how!
Old 07-24-2007, 04:54 PM   #1
grumpyvette
grumpyvette's Avatar
Member #1106
see rods and rod bolt failures blamed frequently when engines self destruct at high rpms, but its NOT always what it at first might appear to be....are there any detailed pictures of the rods or rod bolts that failed??? in many cases the source of the problem can be seen with a careful detailed exam, if you don,t know the SOURCE of the problem your doomed to repeat the sequence... and keep in mind a good deal of what might appear to be rod/rodbolt failures, are ACTUALLY the result of over reving the valve train,and loss of valve train control, OR detonation, theres no way to compress a bent valve or broken piston ring land without potentially damaging the rods
http://www.arp-bolts.com/Tech/T4_Why...4_01_Why0.html
http://www.arp-bolts.com/Tech/T4_Why...4_01_Why1.html
http://www.arp-bolts.com/Tech/T4_Why...4_01_Why2.html
http://www.arp-bolts.com/Tech/T4_Why...4_01_Why3.html
http://www.arp-bolts.com/Tech/T4_Why...4_01_Why4.html
http://www.arp-bolts.com/Tech/T4_Why...4_01_Why5.html
http://www.arp-bolts.com/Tech/T4_Why...4_01_Why6.html
seven words
USE A STRETCH GAUGE and ARP BOLTS
http://store.summitracing.com/partde...5&autoview=sku
or at a MINIMUM, READ THE INSTRUCTIONS CAREFULLY,at least tighten then loosen and re-tighten to spec EACH BOLT ,THREE SEPERATE TIMES with a QUALITY torque wrench
great
http://www.nationaltoolwarehouse.com...qx/product.htm
ok
http://www.hotrodshack.com/torque_settings.htm
http://www.arp-bolts.com/Tech/TechTorque.html
grumpyvette is offline   Reply w/quote Quick reply to this message
IF YOU CAN,T SMOKE THE TIRES AT WILL,FROM A 60 MPH ROLLING START YOUR ENGINE NEEDS MORE WORK!!"!
IF YOU CAN , YOU NEED BETTER TIRES AND YOUR SUSPENSION NEEDS MORE WORK!!
Similar Threads
C5 Secrets MK#27 C5 Corvette - General Discussion 76 11-10-2015 01:15 PM
selecting rod bolts and connecting rods grumpyvette C3 Corvette 5 07-29-2008 08:52 AM
Pulling the body - where to get info Cetrov C3 Corvette 5 10-03-2006 02:55 PM
I need torque ......specs intimid8r3 C4 Corvette 3 07-27-2006 10:14 AM
Piston to Valve clearance enkeivette C3 Corvette 15 07-25-2005 02:15 AM
