DIY - Coupe Owners: Repairing the Targa Rear Roof Latch - Corvette Forum : DigitalCorvettes.com Corvette Forums
Go Back   Corvette Forum : DigitalCorvettes.com Corvette Forums > TECH Exchange > Articles - Body
Articles - Body Body, electrical, interior, etc.
Old 09-11-2010, 12:40 PM   #1
Junkman2008
Junkman2008's Avatar
Member #71977
2001 Navy Blue Metallic Coupe
While working on my targa roof, I had to flip it over for the first time. Wow, what a eye opener! Take a look at the corner of my weatherstripping:
As you can see, the corner of my weatherstripping is all ate up. It was this way on both sides of the roof. I have never looked at this side of the roof so I had no clue. That's kind of odd as I've had this car 6 years now.
So I ordered me some replacement weatherstripping and went at it. First, you remove the 2 screws that hold the weatherstripping on the roof (one at each end).
You don't want to just start yanking the weatherstrip off the roof. You want it to work for you in removing the parts that are glued on. In order to do this, use a screwdriver to pry at both ends of the weatherstrip in order to pry up as much of the corners as possible. This will keep you from having to scrape the thing for the next 2 hours trying to get all of the old weatherstrip and glue off the corners of the roof.
Once you have pried up as much of the old strip as possible, remove it from the roof. Next, throughly clean the remaining glue and rubber off the corners of the roof. You may find that soaking the area in a little Goo Gone will assist with the removal of the old gunk.
Now to install the new weatherstrip. First off, DO NOT remove the plastic that covers the sticky part of the weatherstrip. That will be the last thing that you do. What you want to do first is locate the edge of the weatherstrip that will sit in the channel closest to the top of the roof. It is somewhat hard to see in this picture but will make more sense as you are looking at your own roof.
Once you get both sides of the weatherstrip in, you are ready to test fit the seating. You are still NOT going to remove the plastic covering yet.
What you are going to do is pull the ends of the weatherstrip in place and make sure that the screw holes in the roof, line up with the screw holes in the weatherstrip. If they do, you are ready to move forward. If they don't, you need to make the necessary adjustments. This is why you haven't removed that plastic. Whatever it is that they use for glue at GM, that stuff is like Godzilla Glue. Once you stick it down, it ain't coming back up.
Now here goes the tricky part. First, stick the Phillips screw back into the weatherstrip (if you have removed it). Next, you are going to bend back the corner of the weatherstrip so that you can remove the plastic that is covering the sticky part. Then you are going to CAREFULLY swing that corner into place, making sure that the sticky part does not touch the roof. Make sure that the Phillips screw hits the hole and once it does, give it a turn or two to start it in. At that point, fully seat the corner allowing the glue to do its permanent bond.
The finished product:
The last thing you will do is treat your new weatherstrip (and your existing weatherstripping with some GM Dielectric Silicone Grease. This is the same stuff used on the inside of spark plug boots and keeps your weatherstripping nice and supple. It also prevents it from getting hard and brittle. Don't cake it on like a mousse, use a nice thin layer. This tube will easily do the entire car.
Now I need to detail my beat up looking roof...
That's it! Stand back and admire the money you saved!
The Junkman
Junkman2008 is offline   Reply w/quote Quick reply to this message
