I was asked(whats the most important tool in the garage) - Corvette Forum : DigitalCorvettes.com Corvette Forums
Go Back   Corvette Forum : DigitalCorvettes.com Corvette Forums > General Corvette Topics > General Automotive & Shop
General Automotive & Shop Non-gen specific technical discussion. Automotive tools, techniques and know-how!
Old 10-29-2007, 03:46 PM   #1
grumpyvette
DC Pit Crew
grumpyvette's Avatar
Member #1106
THAT'S EASY!
its the skill level and experience of the guy or gal IN that garage that determines the level of expertize,and the resulting finished work, hand tools a decent set of jack stands and knowing what your doing will ALWAYS produce better results than all the lifts, compressors,welders etc. in the world in un-skilled hands.
Im a tool junky, IM a firm believer and having the correct tools for any job youll do repeatedly,but while having the correct tools speeds up the work and makes it easier to do, hand tools in skilled hands can do just as much work, and at times get better results, it just takes longer and requires more effort.
you DON,T need to be comfortable, or have the best tools, but you do need to understand what your trying to accomplish and how the parts work, what caused them to fail and what you'll need to do to correctly repair or modify them
having the correct lighting, a lift,air conditioning, cold beers etc, may be nice, but it adds little but added comfort or ease of access to the guy doing the work, its the skills of the guy doing the work and his extensive experience and understanding of mechanics that gets the job done
some reference info
http://forum.grumpysperformance.com/index.php
other than an extensive list of HAND TOOLs
like a VOM meter
timing light
vacuum gauge
fuel pressure gauge
IR TEMP GUN
JACK STANDS
and shop manuals/ and a decent set of diagnostic meters sure helps (ILL POST MY TOOL LIST BELOW)
Id say a good
quality welder,
die grinder
compressor,
DRILL PRESS
QUALITY lift,
are nice but not MANDATORY, because you can usually borrow or sub out some of the work
BTW heres MY TOOL LIST, IVE POSTED BEFORE,.....IF IT FITS IN A COUPLE OF MY PRO SIZED TOOL CHEST ITS A HAND TOOL.....and YEAH IVE GOT 90% or more PLUS of those tools in my tool chest...LIKE I SAID IM A TOOL JUNKY......but the lift, compressor, welders are great but not necessarily mandatory
GRUMPYVETTES BASIC TOOL LIST
l items that may come in handy -not a comnplete list but it will get you started
A set of quick release tools for late model gm fuel lines and a/c line disconnects.
ACETYLENE TORCH
ADJUSTABLE LENGTH PUSH ROD
ADJUSTABLE POINTER ,
Adjustable stand, for dial indicator
Air compressor
Air ratchet
Allen wrenches
Allen wrenches
ASK QUESTIONS (its important to get answers BEFORE screwing up)
ASSORTED FILES
Assorted pliers/vise grips
ASSORTED SOCKETS,OPEN AND BOX WRENCHES 1/2",3/8".1/4" DRIVE
auto xray software
Ball joint press tools
Ball joint separator forks
Battery charger(full size shop type)
Bench grinder w/ wire wheel
bearing press 12 ton hydrolic
Big huge screwdriver which doubles as a pry bar
BORE GAUGE
Brake spring pliers and retaining spring tool
Breaker bar
CAM BEARING INSTALLER
CAM DEGREE WHEEL
CAM HANDLE
CARBIDE BURRS
Carburetor stand
CC Burette Kit/PLUS STAND
Checking springs
chisels (assorted sizes/types)
clamp for compressing calipers
CLUTCH PILOT
Coil spring compressors
COMMON SENSE
Compression gauge
Compression tester
Compressor
CRANK SOCKETS
Creeper
Crows feet
Cutting torch
CYLINDER HONE
Deep sockets
DENT PULLER
DEPTH GAUGE
Dial indicator,
Die grinder
digital meter
Differential Set-up Kit
Distributor wrench sae
Distributor wrench metric
Drain pans all sizes
Dremel tool set to cut rivets etc.
DRIFT PUNCHES (assorted sizes/types)
Drill bits
DRILL PRESS
Drop light (florescent preferred)
Duct tape
Dwell meter for the older cars
EASY OUTS
ELECTRIC SOLDER GUN
Electrical connectors assorted
Electrical tape
Engine hoist
ENGINE LEVELER
ENGINE STAND
Feeler Gages
FIRE EXTINGUISHER co2
FIRE EXTINGUISHER powder
Flexible dwell key for point distributors
FREEZE PLUG INSTALLER
FUEL PRESSURE GAUGE
Full set of assorted hammers all the way up to 5 lb hand held full set of tap and dies metric and standard
Full set of torqze tip screw drivers and sockets male and female all sizes
Full size vice
Gasket scraper 2"
Gasket scraper4"
Gear Pullers (assorted)
GM disk brake caliper Allen key 3/8 and 5/16
GOOD KNOWLEDGEABLE FRIENDS
Grease gun
Harmonic balancer puller
HARMONIC BALLANCER INSTALLER
HONING STONE
Impact sockets
Jack stands and a 2 1/2 -3 ton full size service floor jack
JEWELERS FILES
LAPTOP COMPUTER with diagnostic software
Leakdown tester
LIFTER BORE HONE
LIFTER GROOVE TOOL
Line wrenches
LUIS TOOL
Magnet
MAGNETIC PICK UP TOOL
MAGNIFYING GLASS
Mallet
MANUAL LUBE PUMP
MICROMETERS
MIG WELDER
Mini Valve Spring Tester
MIRROR
Multimeter
Normal screwdrivers all sizes
NUT SPLITTER
OIL CAN
Oil filter and regular spin on filter wrenches.
Oil filter wrench plier type
Oil filter wrench expandable type
Oil pump primer chevy
Oil Pump Primers hydrolic
ONE NEW SOLID LIFTER
Paint gun
PB BLASTER OIL
Permanent marker
Pipe cutter
PISTON RING COMPRESSOR
Piston stop,
Pitman arm puller
Plasma cutter 200amp
Plasma cutter 60amp
PLASTIC HAMMER
Plastic zip-lock bags
Pneumatic chisel
Pneumatic impact guns 3/8 and 1/2 drive
Pressure bleeder for brakes
PRY BAR
PUSHROD CHECKER
Putty knife
Ramps
Rear caliper piston turning tool
REFERENCE MANUALS
Retracting extension cord
RIFLE CLEANING ROD AND BRUSHES FOR OIL PASSAGES
Ring expander pliers
RING GAP FILER
Rochester idle mixture adjusting tool
ROD BOLT GUIDES
ROD BOLT STRETCH GAUGE
Safety glasses
Sandblaster
SCAN SOFTWARE
Shorty wrenches
Sledge or mall hammer
SMALL FLASH LIGHT
Snap ring pliers internal and external
Speed wrench
SPRING COMPRESSOR
Standard set of drift pin punches, alignment punches, and centering punches.
Steering column lock plate compressor
Steering wheel puller
Stethoscope
Stick/arc welder
STUD INSTALLER
TAPE MEASURE
Taps & dies
Test light
Three or four of every size socket and wrenches plus extensions ETC.
Throw-away vinyl gloves
Tig welder
Timing light
Tire iron
Tire Pressure Gauges
Torque wrench 3/8'
TORQUE WRENCH 1/2"
Transmission jack
Tubing bender
Tubing cutter
Tubing flare tool
Utility knife
Utility knife
VACUUM GAUGE
Valve spring compressor
Wheel chocks (keep cars from rolling)
Wire crimper
surprisingly a good deal of that stuff fits inside three pro-size craftsman tool boxes,that stand 6 feet tall and 40" wide and have 22 drawers each (at $2000 each..ON SALE??) and the stuff like various welders,bearing presses,hoists ETC. don,t take up as much room as you might think, YEAH! its taken YEARS to acquire all that!,
but Ive done lots of minor repairs in exchange for tools guys were not useing
grumpyvette is online now   Reply w/quote Quick reply to this message
IF YOU CAN,T SMOKE THE TIRES AT WILL,FROM A 60 MPH ROLLING START YOUR ENGINE NEEDS MORE WORK!!"!
IF YOU CAN , YOU NEED BETTER TIRES AND YOUR SUSPENSION NEEDS MORE WORK!!
Old 10-29-2007, 04:13 PM   #2
Moneypit
Moneypit's Avatar
Member #65258
93 LT1
Dam my two typing fingers hurt gust reading that Your right the craftsman sets are the best bang for your buck and don't forget a pair of overalls a bar of lava soap and lots of patience. Nice write up grumpyvette
Moneypit is offline   Reply w/quote Quick reply to this message
Old 10-29-2007, 04:14 PM   #3
Z-MAN
Mo-Fo
Z-MAN's Avatar
Member #8268
Nothing to do today, huh Grump?
Z-MAN is offline   Reply w/quote Quick reply to this message
427 Heaven
Old 10-29-2007, 04:22 PM   #4
grumpyvette
DC Pit Crew
Member #1106
partly new post to answer a question,partly a RE-post of old info that fit the question
Old 10-30-2007, 09:30 AM   #5
B Hetzel
Member #64470
IMHO, one of the most important tools for the weekend wrench is the correct service manual for your car.
B Hetzel is offline   Reply w/quote Quick reply to this message
Old 10-30-2007, 09:35 AM   #6
Dan85Vette
Dan85Vette's Avatar
Member #9092
'85 Vette - 383 TPI
Thanks Grump, fantastic list! I was expecting patience and a lot of beer.
Yea I use my grabber tool alll the time, so many places to drop things in a C4. Since my dad-in-law got me full set of Craftsman wrenches, I've been using them quite a bit. They definitely can take a beating.
I'll have to wait a bit for my welder, but I enjoy using 'em. Always a use for a welder.
Dan85Vette is offline   Reply w/quote Quick reply to this message
Old 11-13-2007, 03:50 PM   #7
68 Shark
Member #65538
hummm I'd have to agree with the service manuals, floorjack and jack stands.
I like to have one of those low profile light weight aluminum race jacks that only require 3-4 pumps to full lift. Easier to manuver around the car and fit in tight spaces.
Then I like to have one of those big heavy duty jobbers as a precautionairy measure and if things get complicated.
Make sure that whatever floor jack you get it eases down fluidly.
I had this big floor jack that you would loosen the handle and nothing would happen then all of a sudden the damn thing would drop an inch or so.
Always use jack stands. I have a set of 4 tall bulky ones when the entire car needs to be up in the air and a set of 2 small yet strong ones when I only need to raise it up a tad to get some work done.
I also find a tiny bottle jack handy sometimes, especially when messing with the rear leaf spring settings.
A pair of good mechanic gloves are always great especially in the winter months and a one peice mechanic suit when its chilly out and you're not so fortunate to have a lift and will be spending time on your back. I have two
I also have ceran wraped an old old laptop (not the vents) that I only have the internet on so I can ask questions/read responses on the net & forum while i'm out wrenching.
AND stay organized...nothing worse then looking for a dang tool that you know you have but can't find. Turns a brake job into a weekend ordeal.
68 Shark is offline   Reply w/quote Quick reply to this message
Old 12-03-2007, 04:32 PM   #8
grumpyvette
DC Pit Crew
Member #1106
a few useful engine related calculators
http://www.idavette.net/tech/ratioc.htm
heres some calculators you might use
http://www.angelfire.com/fl/procrastination/motor.html
http://www.bgsoflex.com/holley.html
http://www.rickwrench.com/bunchofcalculators.html
http://hotrodworks.net/hotrodmath/hotrodmath.html
http://forum.grumpysperformance.com/...hp?f=50&t=5893
http://kb-silvolite.com/calc.php
http://www.wallaceracing.com/dynamic-cr.php
http://www.dsm.org/tools/calchp.htm
http://www.wahiduddin.net/calc/calc_hp_dp.htm
http://users.erols.com/srweiss/calccr.htm
http://users.erols.com/srweiss/index.html#jcalc
http://wahiduddin.net/calc/calc_da.htm
http://www.diamondracing.net/cocalc.htm
http://www.crower.com/misc/valve_timing_chart.html
http://www.bob2000.com/carb.htm
http://www.ondoperformance.com/page2.html
http://www.rbracing-rsr.com/camshaft.html
http://www.rbracing-rsr.com/runnertorquecalc.html
http://www.engr.colostate.edu/~allan...ngth/pipe.html
http://www.rceng.com/technical.aspx
gear spread sheet that comes in handy THANKS TO 1FATGMC
http://purplesagetradingpost.com/sum...eet-index.html
HERES OTHER INFO LINKS
http://www.wallaceracing.com/reargear.htm
http://users.erols.com/srweiss/calcmph.htm
http://users.erols.com/srweiss/calcrpm.htm
http://users.erols.com/srweiss/calcrgr.htm
http://users.erols.com/srweiss/transc.htm#tabtop
http://users.erols.com/srweiss/transc.htm#Auto
http://www.pipeflowcalculations.com/airflow/index.htm
http://victorylibrary.com/mopar/header-tech-c.htm
http://www.uucmotorwerks.com/html_pr...torquemyth.htm
http://tom.marshall.tripod.com/exhaust.html
http://www.engr.colostate.edu/~allan...a/effarea.html
http://www.pontiacracing.net/js_header_length1.htm
http://www.wallaceracing.com/runnertorquecalc.php
http://auto.howstuffworks.com/question172.htm
http://www.auto-ware.com/software/eap/eap.htm
a few resources to allow you to calculate the ideal results
heres some differant calculators
http://www.kb-silvolite.com/calc.php?action=comp2
http://www.smokemup.com/auto_math/compression_ratio.php
http://not2fast.wryday.com/turbo/com...pressure.shtml
average the results
Old 12-03-2007, 04:46 PM   #9
73VetteGirl
73VetteGirl's Avatar
Member #63467
73 & 76 StingRays
Originally Posted by Moneypit View Post
Don't forget a pair of overalls a bar of lava soap and lots of patience. Nice write up grumpyvette
Nice write up Grumpy...Uhmmm now I need to go shopping...Anyone need overalls????
73VetteGirl is offline   Reply w/quote Quick reply to this message
39 ForEver
Don't take life so seriously ... it's not permanent.
Old 09-10-2008, 09:21 AM   #10
jjwvette
jjwvette's Avatar
Member #19167
2007 Z51 Coupe Blk/Mod Red\03 Z06 TR|BLK(sold)\99 Roadster (sold)\ 1990 Roadster (sold)
Thats leaves me out Hammer and screw driver is all I have
jjwvette is offline   Reply w/quote Quick reply to this message
jjwvette
NCM Lifetime Member
Black/Ebony\ Red 2007 Z51 Coupe
6 Spd. Mods:,Corsa Sport Exhaust
Halltech Venom Air Intake
Lloyds mats,Z06 Spoiler,Cags and
lots of Adams shine
Got it from the EVS Team
Old 11-02-2008, 06:40 AM   #11
ozarkyankee
ozarkyankee's Avatar
Member #50982
59 (stolen in 69) 63 Duntov/BL Gold (sold) 77 (sold) red 65 coupe (11.95 1/4 mi. driver)
the tools of patience and common sence followed by Craftsman, Harbor Freight, etc
ozarkyankee is offline   Reply w/quote Quick reply to this message
Vote democrat. It's easier than thinking.
America: Land of Opportunity - especially if you are here illegally.
Bush - no child left behind policy
Obama - no president left behind
Old 11-03-2009, 07:10 AM   #12
CFD E59
CFD E59's Avatar
Member #84563
1970 convertible LS5
ELBOW GREASE...
CFD E59 is offline   Reply w/quote Quick reply to this message
Many have given some, some have given all. To all who have given , Thank you
Old 11-03-2009, 08:12 AM   #13
MassDriver
MassDriver's Avatar
Member #38012
Blacked Out '05
When all you have is a hammer, every problem is a nail!
MassDriver is offline   Reply w/quote Quick reply to this message
Old 11-07-2009, 06:12 AM   #14
midnite902
midnite902's Avatar
Member #36958
05 C6 Z51 DSOM 1SX, MN6 Built by 21st Century Musclecars
I think the proper terminology is: When all you have is a Ford Tool, every problem is a nail!
midnite902 is offline   Reply w/quote Quick reply to this message
C6 Z51 1SX, MN6, Stroked LS7 442ci, TrickFlow 225 Heads, 21CMC Road Race Cam, Kooks,
Balanced Z06 Clutch/Flywheel, Callaway CAI, Ported Fast90, Polished TB, LPE 100mm MAF, Brembo Gran Turismo,
Ron Davis Radiator, Dewitts Hi-Flow, CCW C-10 275s/325s Bridgestone RE05a
534rwhp 512rwtq -
"Things are more like they are today than they have ever been before"
Dwight D. Eisenhower
Old 06-19-2010, 11:43 AM   #15
herriot
Member #100392
c3 ,c5, corvette based rod under construction at (www.hotrod.ie)
how about a decent sterio knockin out some blues/rock n roll cant be beat
herriot is offline   Reply w/quote Quick reply to this message
Similar Threads
tool and check list grumpyvette General Automotive & Shop 2 07-24-2007 04:29 PM
Posting this for a member Patrick Stingray's "Bad Shark" Lounge 0 06-28-2005 12:22 PM
Cop.... donut car? Patrick Other Cars, Trucks & Cool Rides 8 08-23-2003 08:08 PM
