3d Printed Distributor Cover *pics* - Corvette Forum : DigitalCorvettes.com Corvette Forums
Go Back   Corvette Forum : DigitalCorvettes.com Corvette Forums > C4 Corvette Forums > C4 Corvette
C4 Corvette General | Technical | Performance | Aftermarket | Discussions
Old 10-16-2016, 10:08 PM   #1
wd40
wd40's Avatar
Member #60787
1979 with 87 tpi engine
I have a C3 but thought this belonged in the C4 section since the engine is from an 87. When I bought the car it already had the TPI motor in it. Recently I had to take it apart down to the heads due to corrosion. So since I had it apart I thought it was a good time to paint it all and make a cover since I never had one before.
I have a 3d printer handy and thought this was a perfect task for it. So after a day of measuring, modeling, and test fitting, this is my final result for a cover. This is as it was printed, I plan on painting it with the same paint I used for the rest of the parts. This is printed in black abs plastic.
Catch ya later,
wd40
wd40 is online now   Reply w/quote Quick reply to this message
WD40 was first made in 1953, named for being the Water Displacement formula, perfected on the 40th try. Does the year sound familliar?
Old 10-17-2016, 06:51 PM   #2
The Torch
The Torch's Avatar
Member #799
2004 Black/Mod Red-Z06
That's cool. DIY sure has come a long way
The Torch is offline   Reply w/quote Quick reply to this message
Old 10-18-2016, 02:48 PM   #3
raidmagic
raidmagic's Avatar
Member #1067
Rare 1987 bright red
Not bad. I'm in love with these printers. It needs to go to flat and be a little longer to be stock.
raidmagic is offline   Reply w/quote Quick reply to this message
Sampson 9/22/97-1/1/05
Old 10-18-2016, 04:52 PM   #4
autowiz
autowiz's Avatar
Member #149514
2000 silver/black
Very cool indeed. Please report back to us how the abs holds up to heat cycles.
