How Much Boost Can a Stock Engine Take? - Engine Masters Ep. 26 - Corvette Forum : DigitalCorvettes.com Corvette Forums
Old 02-10-2018, 06:29 PM   #1
Maniacmechanic1
Account Disabled.
Member #176497
https://youtu.be/n9pykOaMs5I
Old 02-10-2018, 06:31 PM   #2
Maniacmechanic1
Account Disabled.
Member #176497
60 W Racing oil in this test.
Beating the shit out of this engine.
Old 02-10-2018, 06:46 PM   #3
Maniacmechanic1
Account Disabled.
Member #176497
765 HP.
Not Bad.
Old 02-10-2018, 06:52 PM   #4
Maniacmechanic1
Account Disabled.
Member #176497
This Test Session Also Proves the Old 5/64" GM Piston Ring Packages are not really that bad after all.
Something I have known myself for a long time.
No Piston Ring Blow By under boost.
No crankcase evacuation pump used.
Thin piston rings was heavily promoted by David Vizzard.
They are pretty much obsolete now the old GM piston ring packages stock.
Old 02-10-2018, 07:18 PM   #5
Maniacmechanic1
Account Disabled.
Member #176497
Might be getting ahead for a few new guys...
The Number 1 killer in many Boost Power adder engines is lack of oil control or actual engine oil into the combustion chamber.
Either from valve guides, valve stem seals, piston to cylinder wall clearances, piston rings themselves not sealing proper.
Add oil in under Boost and its Instant engine failure.
It Blew up.
Recalling one Pontiac Guy stating he pushed to 800 HP on Kieth Black Hyper pistons.
He was telling the Truth.
Old 02-10-2018, 07:35 PM   #6
Pops71lives
Pops71lives's Avatar
Member #132985
Any advantage to dry sump? Certainly more volume. Just curious.
Pops71lives is offline   Reply w/quote Quick reply to this message
Old 02-10-2018, 07:41 PM   #7
Maniacmechanic1
Account Disabled.
Member #176497
On a Corvette Yes it helps.
Your sig. has been edited by the admin. Stop now.
Old 02-10-2018, 07:44 PM   #8
Maniacmechanic1
Account Disabled.
Member #176497
Dry sump is not used by many because the cost to setup Drysump on a SBC & BBC Is around $3500-5000.
Used in High End Drag Racing & Road Race Cars.
Also used in all Dirt Track Race cars other than Street Stock V8 class & 4 cyl entry classes.
The Following User Says Thank You to Maniacmechanic1 For This Useful Post:
Pops71lives (02-10-2018)
Old 02-10-2018, 09:13 PM   #9
72SBVet
72SBVet's Avatar
Member #69345
I like when they did the nitrous on the 305. The top ring butted together and it knocked a chunk of piston out, but it didn't hurt the bore very much. Always heard that boost had more stress on the piston and not the rods as opposed to nitrous which puts more stress on rods.
72SBVet is offline   Reply w/quote Quick reply to this message
As FPSRussia says "As always.... Have nice day"
Old 02-11-2018, 02:20 AM   #10
Maniacmechanic1
Account Disabled.
Member #176497
Centrifugal Superchargers have a different Boost Map curve than Roots Superchargers.
Nitrous hits so mean when you use it in straight 350-750-900 HP Shots.
I have seen Big Chevys crack right in 1/2 or straight down the Mains into the lifter valley from big nitrous.
Old 02-11-2018, 03:58 AM   #11
The Torch
The Torch's Avatar
Member #799
2004 Black/Mod Red-Z06
That would suck BIG time
The Torch is online now   Reply w/quote Quick reply to this message
