18 x 10 wheel test-fit - Corvette Forum : DigitalCorvettes.com Corvette Forums
Old 01-21-2019, 08:39 PM   #1
lsejlowe
DC Pit Crew
lsejlowe's Avatar
Member #6680
black '69 350/350 4spd
In preparation to pull the trigger for a new set of wheels I bought one 18 x 10 American Racing Torq Thrust II VN215 with matte gray center to use as a test-fit wheel. I had a 265/40R18 tire mounted on it and it worked perfectly to verify the correct backspacing I needed for the new wheels. It has a +6mm offset (5.75" backspace) which is more backspacing than most people would be willing to run on a stock car. However, I was able to use a few other tools to confirm how much I needed to adjust to get the clearance I needed.
To check the fronts I used a 1.25" wheel adapter to simulate a 4.5" backspace. I checked both sides and found that I had plenty of clearance at full lock. With the wheel turned all the way in I had 7/8" clearance to the stock sway bar and 1" clearance to the nose support bracket. With the wheel turned all the way out I had 3/4" clearance to the frame rail. So with an 18" wheel I could have gone for 5" backspacing and probably not had any contact, but the 4.5" BS gave me the right relationship to the fender that I wanted, so I left it at that.
For the rear I used some 0.2" thick washers to approximate a 5.5" backspacing. With the spacers I found that I had 3/8" clearance to the leaf spring bolt and 1/4" clearance to the frame kick-up, but I did have a slight interference with the parking brake bracket on the trailing arms. With just a little grinding on that bracket I could have run 5.5" BS without any concern, but I opted to push the wheel a little further out to fill the wheelwell a little more and went with 5.375" BS.
If anyone has interest in this wheel for test fitting purposes or for actual use on their car just let me know. It's basically pristine having only had a tire mounted and un-mounted one time. No road miles whatsoever. I'll cut you heck of a deal!
lsejlowe is offline   Reply w/quote Quick reply to this message
Optimists think the glass is half full.
Pessimists think the glass is half empty.
Engineers realize it's twice as big as it needs to be.
Old 01-22-2019, 02:52 AM   #2
The Torch
The Torch's Avatar
Member #799
2004 Black/Mod Red-Z06
I'm not seeing any pics
The Torch is offline   Reply w/quote Quick reply to this message
Old 01-22-2019, 06:45 PM   #3
blueday
blueday's Avatar
Member #49549
79 VETTE
I want to see too!
blueday is offline   Reply w/quote Quick reply to this message
Old 01-22-2019, 07:51 PM   #4
Metalkid
Member #92641
1978 Silver Anniversary Model #678
Same here!
Metalkid is offline   Reply w/quote Quick reply to this message
Old 01-26-2019, 06:29 AM   #5
lsejlowe
DC Pit Crew
lsejlowe's Avatar
Member #6680
sorry, you've gotta buy the wheel to see the pics!
I've struggled with this in the past with embedding pics from google photos. I can see them just fine, but the rest of the world cannot. Let me see what I can find for a workaround...
--edit--
OK, I think I got it to work now. Seems to have been a share setting issue which would explain why I could see them on my end (logged into my google account) but no one else could see them. Had to add them to a shared album and re-link.
Here's a pic of the end result with the new wheels. Please tell me you can see them now!
The Following User Says Thank You to lsejlowe For This Useful Post:
rusted40 (01-26-2019)
Old 01-26-2019, 07:48 AM   #6
rusted40
rusted40's Avatar
Member #171138
nice, what were the final specs on the wheels?
rusted40 is offline   Reply w/quote Quick reply to this message
Old 01-26-2019, 01:51 PM   #7
lsejlowe
DC Pit Crew
lsejlowe's Avatar
Member #6680
Here are the deets on the new wheels:
new 18" wheels: Team III LT-III
Wheels:
Manufacturer: Team III Wheels
Model: LT-III
Front Specs: 18x10 w/ 4.5" backspace
Rear Specs: 18x11 w/ 5.375" backspace
Tires:
Michelin Pilot Super Sport
Front Size: 265/40ZR18
Rear Size: 295/35ZR18
Old 01-27-2019, 10:23 AM   #8
Marks76ray
Marks76ray's Avatar
Member #87984
1976 Stingray
Nice write up, anyway that 295 can be run on the front?
My Build Link https://www.digitalcorvettes.com/foru...d.php?t=148376
My Picture Link
http://www.supermotors.net/users/Busterbronco
rely-Definition of
Depend on with full trust or confidence.
synonyms: depend on, place reliance on;
Old 01-27-2019, 11:52 AM   #9
autowiz
autowiz's Avatar
Member #149514
2000 silver/black
Offset trailing arms from van steel will make those wheels fit real nice in the back.
Old 02-09-2019, 04:51 PM   #10
TommyFox
TommyFox's Avatar
Member #117042
C4 1989
Yes I ran a 17X 10 with a 315 on my 81. Flush with the fender but had to go with a custom sway bar.
TommyFox is offline   Reply w/quote Quick reply to this message
Spaz
Old 03-17-2019, 03:38 AM   #11
cole sweat
cole sweat's Avatar
Member #163833
BB 69 Coupe
What year is your car and do you have flared fenders
cole sweat is offline   Reply w/quote Quick reply to this message
Old 04-14-2019, 08:04 PM   #12
lsejlowe
DC Pit Crew
lsejlowe's Avatar
Member #6680
'69 and yes, I have 2" CIC flares on all 4 corners
Old 04-16-2019, 11:17 PM   #13
OldCarBum
OldCarBum's Avatar
Member #181270
1973 Big Block Coupe
Great information, Thanks for posting.
OldCarBum is offline   Reply w/quote Quick reply to this message
