Rumored: About 30 C8 Prototypes Produced at BG - Corvette Forum : DigitalCorvettes.com Corvette Forums
Go Back   Corvette Forum : DigitalCorvettes.com Corvette Forums > C8 Corvette Forums > C8 Corvette
C8 Corvette General | Technical | Performance | Aftermarket | Discussions
Old 04-14-2019, 03:59 PM   #1
Longtimer
Longtimer's Avatar
Member #3668
'07 Z51 6Mn NCM delivery, '79 L82 4 sp gymk - Gone '87 Z52 4+3, 76 L-82 4 spd
Were 30 C8 prototypes recently produced at the Bowling Green Factory? Maybe. BG has been capable of producing two separate models at the same time since the C5/C6 transition. GM's Holden Austrailia Division was one of the first to master the ability to produce diverse models on a single assembly line and BG began adopting their methods early in this century. Therefore it is EXTREMELY likely that some C8 are at the very least, going through some pre-production processes and NOT unreasonable to assume that 30 might have been produced over some night shift(s) at BG. The new size of the BG plant, no doubt, provides plenty of covert storage for this very reason.
Here is a link to a vid showing 3 cammoed C8s heading North from BG on I75 northbound just North of Lexington, KY, taken by a trucker shortly after the rumored surfaced. So FWIW, the attached could be spy shots of VERY early production/pre-production C8s:
https://youtu.be/3thnqA435WY
Longtimer is offline   Reply w/quote Quick reply to this message
'07:bought from a former sponsor, Z06 wheels and Vararam from former sponsors, Various accessories from Corvette Central and Corvette America. B&B Fusions with Corsa X pipe. Shine from Adam's
'87: refurbished all interior with parts from Corv Central '79: Interior refurb = Corvette America, and Corvette Central, T1Rs, Foose Legends
DC Sponsors
________________________________________ ________
Corvette ownership is like owning your own fountain of youth ... and we get a sip from it each time the signal turns green. Watching for C8 fixes & improvements
The Following User Says Thank You to Longtimer For This Useful Post:
stinger430 (04-16-2019)
Old 04-15-2019, 02:55 AM   #2
The Torch
The Torch's Avatar
Member #799
2004 Black/Mod Red-Z06
Someone needs to thank that trucker
The Torch is offline   Reply w/quote Quick reply to this message
The Following User Says Thank You to The Torch For This Useful Post:
Old 04-19-2019, 07:26 AM   #3
mhousto
mhousto's Avatar
Member #17583
2003 Zo6
Tire size
Skinny tires, must be the Stingray. Hopefully the ZR1 will have big Merican size rears.
mhousto is offline   Reply w/quote Quick reply to this message
Old 04-19-2019, 02:34 PM   #4
Longtimer
Longtimer's Avatar
Member #3668
First, yes it is VERY likely IMO that these were Stingrays. The C8 is such a radical change with so much new technology, it is essential that the productionline-produced cars get wrung out on the streets thoroughly and rack up plenty of miles of every possible scenario.
Second, "skinny tires" ??? !!!?? Ok, I guess that is a subjective adjective. That said, all Rear mids run fat tires out back and less-fat tires in front. The Stingray's tire sizes were revealed via spy pics long ago:
245/35ZR19 in the front equivalent in size to the fronts of the C7 Stingray
305/30ZR20 in the rear- notably wider than the rears on the C7 Stingray
Be careful NOT to make any judgements about the tire size comparisons to the FRONT engine C7. The traction requirements are completely different. That said the C8 Stingray rear tires are not as wide as those on the C7 Grand Sport, Z06 or ZR1. Because the C8 will have MUCH better rear tire hookup, it's possible that even in the higher performance models, tires larger than respective C7 models might not be needed or desired for optimal handling.
DC Sponsors
Similar Threads
C8 + C8 + C7 ZR1 Video Longtimer C8 Corvette 1 07-25-2018 08:04 PM
vette prototypes 200+LS7V8Z06 General Corvette Topics 3 08-16-2008 07:47 PM
All Corvette Prototypes on one website cenobyte Corvette History 2 12-26-2007 04:36 PM
