Use the check boxes to select/deselect areas to print.
Lubricants & Fluids:
Chassis Lubrication
Torques
Filters
Capacities
Other Top Quality Products
Click Here to Print What You Have Selected
1999 CHEVROLET TRUCKS TAHOE 5.7L 8-cyl Engine Code [R]
FILTERS:
Oil Filter
25,000-Mile Ea Oil Filter (EAO24) [1] Oil Filter
25,000-Mile Ea Oil Filter (EAO23) [2] Oil Filter
WIX 51060 Oil Filter [3] Oil Filter
WIX 51036 Oil Filter [4] Air Filter
WIX 46441 Air Filter [5] Air Filter WIX 46440 Air Filter
[6] Transmission Filter
WIX 58904 Trans Filter [7] Transmission Filter
WIX 58847 Auto Tran Filter [8] Transmission Filter
WIX 58608 Auto Tran Filter [9]
[1] RWD (DriveType)
[2] 4WD (DriveType)
[3] Manufacturer OE Recommended Oil Change Intervals; RWD (DriveType)
[4] Manufacturer OE Recommended Oil Change Intervals; 4WD (DriveType)
[5] Heavy Duty
[6] Light Duty
[7] 4L60E - Shallow Pan
[8] 4L60E - Deep Pan
[9] 4L80E
CAPACITIES:
Engine, W/ OOP, with filter..........5.9 quarts
[1]
Engine, W/O OOP, with filter..........5 quarts
[1]
Cooling System, With AC Initial Fill..........20.1 quarts
Passenger Car & Light Truck Antifreeze & Coolant
AMSOIL Antifreeze and Engine Coolant
Cooling System, Without AC Initial Fill..........17.4 quarts
Automatic Transmission, 4L60-E Initial Fill..........5 quarts
Automatic Transmission, 4L80-E Initial Fill..........7.7 quarts
Automatic Transmission, Total Fill
4 speed 4L80-E..........13.5 quarts
4 speed 4L60-E..........11.2 quarts
Differential, Front..........3.6 pints
Differential, With 10.5 RingGear Rear..........6.3 pints
Differential, With 11 RingGear Dana Rear..........8.5 pints
Differential, With 8.5, 8.625 RingGear Rear..........4.2 pints
Differential, With 9.5 RingGear Rear..........5.5 pints
Transfer Case, NP241, NP243..........4.4 pints
[2]
[1] After refill check oil level.
[2] Identification: check tag on case.
