Front, front mid, rear mid / mid, rear - Chassis definitions - Corvette Forum : DigitalCorvettes.com Corvette Forums
Go Back   Corvette Forum : DigitalCorvettes.com Corvette Forums > C8 Corvette Forums > C8 Corvette
C8 Corvette General | Technical | Performance | Aftermarket | Discussions
Old 07-26-2016, 03:53 PM   #1
Longtimer
Longtimer's Avatar
Member #3668
'07 Z51 6Mn NCM delivery, '79 L82 4 sp gymk - Gone '87 Z52 4+3, 76 L-82 4 spd
Clarifications for newcomers:
Front Engine: Engine and usually transmission are placed forward of the passenger compartment. Most often the engine sits over the front axle line. Note: many front wheel drive engines are placed ahead of the front axle line.
Front Mid Engine: The Engine is placed mostly or completely behind the front axle line, but ahead of the passenger compartment.
Rear Mid Engine / Mid Engine: The engine is placed ahead of the differential and behind the passenger compartment. The transmission might be forward of the differential, integral to the differential, or rearward of the differential.
Longitudinal Mid Engine: The engine is placed length ways - front to back - ahead of the differential.
Transverse Mid Engine: The engine is placed with the front of the engine facing one of the sides of the car. Most frequently a belt is used to drive a transaxle (like a front wheel drive). This enables a compact layout but power / torque is usually limited due to the limits of existing transaxles.
Rear Engine: Engine is placed behind the differential. (Porshe 911, Corvair, original VW Beetle).
Longtimer is offline   Reply w/quote Quick reply to this message
Corvette ownership is like owning your own fountain of youth ... and we get a sip from it each time the signal turns green.
Old 07-26-2016, 04:22 PM   #2
XQIZT
You've been pimped!!
XQIZT's Avatar
Member #80197
Current: 2002 Z06, 1977 custom Past: 1985 Z51 Coupe
I like the new section!
So we can say current Corvettes are "front mid" configurations, right?
XQIZT is offline   Reply w/quote Quick reply to this message
"Bella" - 2002 Z06 - Carrying on family tradition of Corvette ownership.
"Alexa" - 1985 Z51 - In memory of the last Corvette Dad owned. Gone but never forgotten.
"Desiree" - 1977 - Wife's car, with an attitude problem.
Click here for more info about our cars and autocrossing and other Corvette stuff.
Old 07-26-2016, 04:40 PM   #3
Longtimer
Longtimer's Avatar
Member #3668
Yes. But I don't mean to sound restrictive. The definitions are ONLY HERE to help some of the discussions along without misunderstandings.
That said, I usually post "front mid" because there are some members who are finicky about the "Front Mid" label and will post to request a correction / clarification.
Good question.
