thermostat water outlet bolts - Corvette Forum : DigitalCorvettes.com Corvette Forums
Old 06-12-2019, 05:37 AM   #1
teamo
Member #135985
1975 Coupe
1975 corvette. Are any flat or lock washers used on the thermostat housing bolts? The AIM did not show the bolt detail.
teamo is online now   Reply w/quote Quick reply to this message
Old 06-12-2019, 07:06 AM   #2
Maniacmechanic1
Maniacmechanic1's Avatar
Member #176497
You can if you want to.
Or use a small hardened steel flat washer.
It's Ok to be Hated by Autowiz and called a fake Trans Am Owner.
Does not matter on Street Race night here in Illinois.
I am the Legend that Beat the 572 CI Corvette.
Old 06-12-2019, 04:50 PM   #3
teamo
Member #135985
1975 Coupe
I know that I can use a washer but I am trying to do it as it came from the factory. I was justs wondering if anyone knows if it came with washers from GM.
Thanks
Old 06-12-2019, 09:02 PM   #4
Maniacmechanic1
Member #176497
Thanks
I have seen them with washers and without.
Try Google searching images.
Type in what you want end with images.
Pictures come up others posted.
I do that often to find out myself what was correct day 1.
Old 06-12-2019, 10:01 PM   #5
7TRoadster
7TRoadster's Avatar
Member #106320
1970 Roadster, Mast Motorsports LS7, TKO 600, SS Frame, C4 suspension
Here is a photo of the original engine out of my 1970 Corvette. It had about 68k original miles on it when purchased, it was the base 300hp 350 engine. I have no reason to believe this has ever been removed from the cast iron manifold.
Hope this helps....
Click image for larger version
7TRoadster is online now   Reply w/quote Quick reply to this message
The Following User Says Thank You to 7TRoadster For This Useful Post:
The Torch (06-13-2019)
Old Yesterday, 05:48 AM   #6
teamo
Member #135985
1975 Coupe
Looks like the '70 had no washers so they probably stuck with that going forward. I have seen some of them with one stud and one bolt as in 7Troadster's picture. What is the purpose of the stud there doesn't seem to be anything that bolts on top of it?
Thanks
Old Today, 08:42 AM   #7
7TRoadster
7TRoadster's Avatar
Member #106320
I looked through the accessories section of my AIM and it shows the smog pump mounting in that area. It's likely a bracket mount for the pump, which back then would have been CA cars only.
Alternatively, I have seen other Chevy's with hose/wire loops mounted there.
Old Today, 09:36 AM   #8
teamo
Member #135985
1975 Coupe
I think you're onto something with the stud. I think the smog hose went over the top near the water outlet and over to the left side exhaust manifold in the early years.
