C-3 1975 Corvette 4 Speed rear wheels are locked up - Corvette Forum : DigitalCorvettes.com Corvette Forums
Old 09-21-2019, 05:01 PM   #1
baskett-2
Member #119433
2002 Corvette Convertible
Hey everyone was driving my 75 yesterday about mile into it the rear wheels just locked up. I was unable to even push the car to the side of the road. I was able to get it back home. I have been trying to figure out what is wrong. I took the caliber off and tried to turn it (nothing). Took the brake pads out from the other side still (nothing). There was nothing out of the ordinary only that it came to an immediate stop. I looked at the emergency brakes it appears to have lots of shoe left doesn't appear to be seized. The cable under there looks pretty bad and there is no emergency brake when you pull it up inside. I The Transmission was just rebuilt in it as well. I got into the car cranked it up and put it in gear hoping with no weight I would get something to move. Nothing it just boggs down and kills the motor. Come now I need some help to put me on the right track to get er fixed. Thanks Dean
baskett-2 is offline   Reply w/quote Quick reply to this message
Old 09-22-2019, 11:03 AM   #2
7TRoadster
7TRoadster's Avatar
Member #106320
1970 Roadster, Mast Motorsports LS7, TKO 600, SS Frame, C4 suspension
Next I would try to isolate the problem further. Disconnect the drive line and push it slightly forward to clear the flange. You should be able to tell if it's the differential or transmission by turning the flange. Go from there.
7TRoadster is online now   Reply w/quote Quick reply to this message
Old 09-26-2019, 06:01 AM   #3
gtr1999
gtr1999's Avatar
Member #44662
69 & 72
Disconnect the driveshaft at the differential pinion yoke.
See if the pinion moves, if not disconnect the 1/2 shafts at the diff and try again.
Most likely it is a backed out ring gear bolt or a broken posi. Once the diff is disconnected from the shafts it should freely move, if the parking brakes are broken and jammed up typically the diff will drive through them. With the shafts free of the diff the wheel should move free as well.
Look up my diff threads here in the tech page for pictures that might help you.
gtr1999 is offline   Reply w/quote Quick reply to this message
Gary
69 vert 350 M20-373's
72 coupe 350,TH400,336's
Old 09-28-2019, 02:36 PM   #4
garys 68
Member #94630
68 vert
Differential broke or you're stuck in 2 gears in the trans, usually reverse and a forward. Disconnect the driveshaft like GTR said, start it, let out the clutch.
garys 68 is offline   Reply w/quote Quick reply to this message
Old 09-29-2019, 09:41 PM   #5
zimmej51
zimmej51's Avatar
Member #171434
I'd say do all of the above, that's a good diagnostic procedure. One other possibility is that one of the hub bearings in the trailing arm has failed and locked up. These hub bearings have a history of failing, usually because the lubricant (grease) has broken down. Several outfits make a re-greasing tool but it is a PITA to use. To find out for sure, remove the half shafts and see if the rear wheel(s) will turn.
zimmej51 is offline   Reply w/quote Quick reply to this message
