1 - 20 of 37 Posts
· Banned
Here's a vid of my C6(L92/L76 combo) at Rockingham vs a stock(except for PS2 tires) 04 Z06. The times shown tell the story of bad traction,high humidity,95 degrees air temp,and 120+ degrees track temp.
BTW, the regulars at the track said their times were off by .5 to 1.0 from normal due to the conditions.That's put the Z in the 12's and my car in the 11's easily.:thumbsup:
120 trap speed not bad:thumbsup: easily in the 11's. Are you still running the run flats?
L92/L76 combo w/ mild cam and lg headers & tune. Stock exhaust and everything else,tires too, unfortunately.
The weather made a huge affect on your et last time out,you went 12.2 in 95 degree air and 12.05 in 45 degree air in january. Right there is 5 tenths in the 1/4 because of the 50 degree temperature change! Trust me you will see 11.80's this fall when cooler air arrives with higher traps also. If you are trying for a new best I wouldn't even bother taking your car to the track until you have a nice cool day because heat kills the performance on these cars.Good luck!
Yeah, lets see a vid of that 11.70 stock run:huh:
I believe you, I don't doubt the skill... I'd just love to see a video of it
1 - 20 of 37 Posts
