anyone using the 16 inch tt II's , (on a 73 vette or close) ???? As craig said to previous poster,,,, ask around. I want to go 16in to have more side wall (bad roads), than the 17's seen on alot of cars here.
If you are running the 16 in.,,,,, what size tire & any rubbing up front?
Thanks for any info
Thanks for any info
Strider is running the 18" version, a couple are running the 20", and many 15" versions are being run by members.
If you get the correct offset, and tire width, and tire diameter, you should have little rubbing.
Just be aware that the TT2's expose your brakes really nicely. So, expect to detail your calipers and brakes before mounting those shiney new wheels.
I'd definitely get them from Craig at radicalwheelsinc.com :thumbsup:
