21 - 24 of 24 Posts
Turn the headlight switch " Dimmer " for the interior lights all the way OFF. I believe it's counter clock wise. ( I can't check as my car was stolen some years back ! ). Anyhow, put in
a fresh fuse and try the lights. If the fuse DOESN'T blow, It's most likely the connector as pointed out above....
P.S. If you can't see the photos of the column, try a different web browser....
...................................l2829tad...............................
Thank you. I just realize my network at the office had the phone website blocked, which is why I couldn’t see the images. Thanks again
Keith
Well....I fixed it, but not exactly sure how. After going over every wire possible, and checking connections, I decided to put another fuse in to see what happens and it worked. I think the purple starter wire was either on the block or very close and could have been grounding, although I don't know how it would have cranked or not blown another fuse if this was the case. It's just the only thing that I saw that could have been an issue.
I love getting something to work, but hate not knowing how and now have to constantly worry that the issue will show back up.
Thanks for the help.
Keith
21 - 24 of 24 Posts
