Looking at getting new rotors, calipers and pads for my Z. What size are the rotors on front and back? Also what do I look for in getting calipers? Is there a certain option the Z had?
Thanks
Luke
1991 Brakes
When I bought my ZR1 (April 2005) I replaced the brake pads a month after I bought it. It already had the cross drill/sloted rotors. The pads are still good sixty miles later. All my cars have cross drill/sloted rotors. The pads last longer & the cars stops better. My 2 cents on the subject.
Manfred E........
91 ZR1 #906
http://www.pnwzr1.net
El Teafive
All ZR-1s had J55 Standard on them. (so the bigger 13" brakes)
the rear brakes are the same on all corvettes 89-96. I forget the actual size
so the grandsport Calipers will work on your car without too much work
What I've done is:
Replaced Stock Rotors Front 13" and Rear 12" with Baer Eradispeed Plus slotted/cross drilled rotors of the same size.
Replaced stock front calipers with Grand Sport calipers, they are stronger, with less flex. Painted the rear calipers black. :laughing:
Replaced stock rubber brake lines with braided steel. Much less pedal mush.
I used Baer Sport Touring pads all around. I'm very happy with them. If they wear out I may change to Hawk (Spring Mountain Motorsports swears by them.)
Castrol SRF Synthetic Brake Fluid.
DRM brake bias spring.
Very little work, not a great deal of expense as opposed to going after market oversize, yet with a great deal of braking improvement.
Rich
REBELZ
'92 Yellow/Black ZR-1 #031
