1 - 12 of 12 Posts
You might want to check with one of our suppoting vendors listed to the left...
How did you get a 285 on a 9.5 wheel?
This is what I have:
Ruff Racing 278 Hyper Black in 19" x 9.5" 45mm offset sizes all around.
Rubber is BFG KDW2's - Rear 295/35/19 - Front 255/35/19
Front side shot
Looking from the front back
Straight down on front wheel
Straight on side shot
Rear side shot
Looking from the rear
Looking down on the rear tire
Close up of rear
Close up of front, (I know I still need to scrape the letters on the caliper)
a tread shot of the BFG
another
and a couple more side shots
Looks good. Is your car lowered any? And have you had any rubbing issues on the fenders?
Yup, Lowered on stock bolt adjustments, no cut bushings
No problems whats so ever with rubbing.
I do have a problem with vibration above 65mph, found out I need hubcentric mounts. Got those coming and should be fine after that
Mike
Discussion Starter · #10 · (Edited)
Well I just got them on my T/A. I love the look and couldn't be happier. Hopefully they will look this good on whatever Corvette I pick up when the time comes....take a peek:
#1
#2
#3
#4
#5
#6
#7
#8
#9
#10
#11
Discussion Starter · #12 ·
Thanks!
They are made by TSW. They are called Volcano's and apparently are discontinued from what I've been hearing around.
1 - 12 of 12 Posts
