1 - 8 of 8 Posts
i have a 02 c5 and recently my speedo stopped working. i checked all around the tranny and i dont think the sensor is located there, so i was thinking maybe a speed sensor was on a wheel somewhere but couldnt find it there either. does anyone know what controls the speedo? thanks, pat.
Have you found any info on your problem? Let us know how it comes out...
VSS ( vehicle speed sensor ) I believe it is located in the top of the diff case.I believe it reads ring gear revelutions. Hope that helps
Is your reverse lockout gone too?
While you are driving can you accidentally put it into reverse? If so, speed sensor.
the dic does show correct speed when i have the cruise on. i will look above the diff for the sensor. thanks, ill let you know if i find it.
1 - 8 of 8 Posts
