I have a 2008 C6 that the front turn signals on both sides do not work rear signals work fine. Front flashers also do not work. But the running lights work fine. Any Ideas?
will today, but normally doesn't the signal speed flash fast when a bulb is out?
You are absolutely correct A fast flash will occur when you have a failed bulb. What you are describing is leading me to believe you have a failed flasher relay which is under your dash . The C5 had a lot of these type of failures
