Hi All
Looking to see if any interest in these.
I will be making 4L80E tail housings to convert any 6 speed or 700r4 C4 into a bullit proof 4L80E trans.
Basicly bolt on the tailhousing to a 4L80E use stock 6 speed
C-beam and a stock 6 speed driveshaft and go racing.
These will sell for $649
Please reply here or PM me.
Opinions welcome.
Pete
http://www.vermontsecure.com/cart.a...ap+Kit&PriceEach=599&Qty=1&Submit=Add+to+Cart
http://www.transmissioncenter.net/4L80E.htm
#C480. 4L80E in C4 Corvette Adapter (1984 - 1996). Swap your 700R4 / 4L60E transmission to the much stronger 4L80E transmission with our new double strength case hardened output shaft and adapter kit. At this time we have an adapter kit for the C4 Corvette to replace your 700R4 / 4L60E transmission with the much stronger 4L80E transmission. This 4L80E transmission will be the same length as your 700R4 / 4L60E transmission making it possible to reuse your existing 27 spline driveshaft and C-beam. All that needs to be changed on the 4L80E transmission is the tail housing and output shaft. The full manual shift model works without a computer. This tail housing is made of 6061T6 aircraft aluminum. Cost $599.00
