Are the originals gloss black or flat black. I'm repainting mine while I'm in the process of putting on sidepipes....
Thanks,
Thanks,
Here's the exact stuff I used on my rocker panels and window trim. While searching for the paint I found a link to a person that restored windshield wiper arms......the window trim and rocker panels use the same method. The main thing is to make sure you remove all the flaking paint and feather what is still stuck or chipped out.I need to repaint my window trim and rocker panels,i can see some black at the corners so i guess it wore off over the years. what kind of prep do you need to do with the moulding and panels to get the paint to stick and look good.
Just go to autozone and get a can of duplicolor "Trim Black" spray paint. It's a low gloss that's the same color as the black painted trim around the winshield and rear glass.
I did my rockers with this and they look great, lays down good and it's not too flat or not too glossy.....just right. :thumbsup:
