No spark.
The red/pink wire going into the distributor I believe should be hot with the key on ?
Anyway, using a test light it shows nothing.
Is there a fuse that feeds this ?
Anything else that is the most likely cause ?
No spark.
NO
Fed straight from the IGN switch
Check to see if you have 12V on that wire at switch when key turned on ; switch could be faulty
Put 12V direct from batt to coil terminal and see if engine will start.That will confirm all the other parts of the IGN system are working properly and identify if problem is with power to coil or not
