Well, in short, it looks like the 1985 Rear Upper Mount is not the same as the later years, so I can't weld a washer onto the mount plate and move it, I am not surprised really.
And to top it all off you can see that the mount hole is offset towards the edge of the frame (towards teh car center) and there is a rolled up edge there that prevents you from mounting anything flat on that edge.
It looks like I will have to weld up a mount bracket that replicates the factory mount,, then cut the factory mount off, and weld the new bracket on becasue I can't see how you can get into the boxed frame to put a nut on the mount bolts.
Spoke with QA1 tech today, their big issue with C4's and Coilovers is they say the mounting bracketsare flimsy,, well, I can take care of that, probably will use .250" thick CRS like I did on the front CO tower.
For you guys that have done this mod on later years,,,, do the pics look similar to the later years, except for the shock mount?
ALL PICS BELOW ARE OF THE PASS SIDE SHOCK
Here is a pic of the new spherical bearings that came today, this will help with the apparent misalignment on the shock loop.
You press out the Poly bushing, then press the bearing in and install a snap ring on the ID of the loop on both sides of the bearing. Part # QA1 EMB8-102pk
I cut the Towers off both sides. They are only @ .110" thick so we'll heli-arc weld .125" thick SS to the sides of each tower which will make them @ .245" thick,, then stick weld them back to the car hopefully tmorrow night.
Well, we welded 1/8 thick SS to the side of the stock mount, it ain't pretty, but its pretty strong, it was .105" thick before, now its .235" thick afte rthe SS was added
We also welded a larger base to the mount in an effort to spread out the load, the base is 1/4" thick 1018 CRS
RJ welding the mount on last night @ midnight
Welded on and moved forward 1.250"
Painted and since I kept the factory mount in an effort to make this reversible in the future,, I put a rubber bushing in between the Spherical bushing and the mount wall, I will search out a better solution for this but with teh tires on, you dont see it.
