it seems to be coming out at resevoir nipples and overflow nipple. they are quite loose in their mounting locations. can i just use some solder on these? will it hold with the heat and pressure? anyoneelse dealt with this. the hoses are tight on the fittings its the fittings are actually loose like the welds have broken. any little bit of help is great, and those who've had this issue PLEASE chime in.
finally running again and this is just a minor issue. though with hood open if i goose the throttle you should see the upper radiator hose collapse: looks like the vacuum being applied to it is VERY strong.
