I'm not that familiar with the 6 speed tranny. So, when it growls in 1st and 2nd I'm wondering if this is normal. It start out fine. but around 4,500 rpm in 1st it begins the growl, and continues until I shift. It happens again in second as I approach higher rpm's.
Any thoughts?
I'd drain some of the fluid out into a clear jar and check for any metal that may settle to the bottom. If you find any you may as well yank it before it does any more damage. Also note the color of the fluid. It shouldn't be black and smell burned.
Discussion Starter #4
Supposedly Corvette Mike (dealership) did a transmission service before I bought it.
I will check it though.
