1 - 8 of 8 Posts
can someone tell me what this plug is for on top of the compressor. mine is broken and i want to get a used compressor from ebay if thats a good idea
I've got the compressor off my car if you're interested. It was a working piece when removed. Ask around and if it's ok for it to have sat and will be what you need make me an offer. I'm a reasonable guy.:thumbsup:
funny timing Raid...I have the Vette magazine right in front of me now and am 1/2 way through the artice about your car. Thanks for mentioning your suppliers and beautiful car too!!! AS for the broken thing..It is the clutch switch:cheers:
El Teafive
:huh::spanked: ok thanks!
when your motor is running the A/C Compressor pulley is free spinning. when the A/C is activated, the clutch is activated locking the pulley to the shaft of the compressor allowing the compressor to work.
The compressor will cycle on and off while the A/C is on, depending on pressures, mode of A/C you have selected, etc.
so sometimes the clutch will turn on, then off, then on..
without the clutch, the A/C compressor will never run.
Hope that helps a bit more
1 - 8 of 8 Posts
