hi all its been a while..hope all are good
i have a problem with my A/C on my 94 LT1 4A. it starts blowing hot air suddenly..!!! i took it to a mechanic... it need to change the condencer (leakin or somthing).. is that an easy job to do? if i wanted to it myself, How? and how much a condencer cost?,,, any i dea... i really need the info a.s.a.p itss hot like hell here,,, :surprised
thanks
El Teafive
Condensor is in front of the radiator and looks like the radiator. i am guessing they run about $150 to $200 if i remember right.
Tnen you need to chanrge the system, although before any work can start you should have the refrigerant recovered/removed correctly from the system
Dont forget to Change the filter Acumulator, the orifice and the o-rings are recomended. I always evacuate to 400 microns before I add oil and wiegh in the charge.
It is a fun job and take about 4 hours if you do it all, and make sure that there is no stress on the condenser. :thumbsup:
Discussion Starter #4
Thanks alot for the feed back...:thumbsup:
im right on it..hope i wont do anything to damage it... ill let u know:smack
cheers:cheers:
