1 - 9 of 9 Posts
Its been many years, but fom memory, the numbers are on the inside under the outer cover of the plug-in bar (female side). Each wire is color coded too, so you can match them as shown in the service manual. One problem without using the pinout tool is you wont be able to test the connection at the plug-in bar. But you can look and see if the connections are in good shape. Ive seen bent connecters.
1 - 9 of 9 Posts
