This morning I noticed a weird smell while driving to work, you know like somebody is heating up the room you're in. I check AC on driver's side and it cools. Then after a while I check the passenger side and warm air is coming out. WTF ?!? ... I turned the temp to lowest possible and ALSO the passenger side button to even "more" cold (dual side you know). It doesn't matter, passenger side always heating the room :thud: .
Tell me somone had this problem before.... I really don't have the will to tear the whole AC system appart to solve this one.... :spanked:
Grey Squirrel
Sounds to me like the right air temperature actuator is not functioning properly. Any stored codes?
well, later in the afternoon as I drove back home, AC went back to normal ... I have NO idea why would that happen. I thought AC was broke. Eh... I'll pray that was just an electronic onetime bug....
thanks for the response, sometimes "we" react too quickly, cause we care about our "babies" :laughing:
The actuator door gets stuck sometimes. You can do a quick fix by pulling fuses 18 and 27 in the passenger fuse box before starting the car, then replacing them. It resets the system. It may be a sign of the actuator going downhill though. Mine did that for about a year until it finally gave out. The good thing is the actuator is only about $150, it just takes a little time getting to it.
