So my Ac was working excellent and last month i ihad replaced the hi speed blower relay so all my speeds were working. well last nite i went out and the hi speed is not working and the ac clutch is not engaging. Any thing i should check?
It's possible. My schematic does not show pin #s. I can tell you the black and orange is the coil. Check for continuity across there with the harness disconnected. The dark blu to purple should show continuity. When 12 volts is applied, red to purple should show continuity. Hope this helps.Bird, Good morning, is it possible the AC relay coudlve gone?
Check for 12 volts at the red wire on the relay. Check for 12 volts across the clutch connector.yeah the blower works at all the lower speeds!!!!!!!!!!!!!!!!
