141 - 153 of 153 Posts
· Premium Member
Discussion Starter · #141 ·
Yes you have the sequence I use correct. Feather Fill is a catalyzed primer it dries egg shell hard yet sands well. I used black for the bottom layers and gray for the upper layers. It will easily fill 220 scratches. Be safe, wear a respirator. Because it's catalyzed if you breath it in it will cure inside your lungs, permanently reducing lung capacity.
Important Concepts
Before we go any further, here are some important concepts/disciplines that need to be kept in the forefront of your paint work.
Adhesion: (as applied to painting) The ability of spray on chemicals to stick to a given surface.
In this case primers, filler, paint, etc...... In order for paint to stay on reliably, each sub layer has to stick/adhere to the one below it. There are two types of adhesion, mechanical and chemical.
Mechanical adhesion is provided by the sanding scratches you apply to the surface when sanding/blocking the surface. These very small scratches create random cuts in the surface with rough groves, the primer/paint will flow into these and when dry form a mechanical bond. It's important to sand between coats of primer to maintain the mechanical adhesion.
Chemical adhesion is accomplished when two layers can be chemically bonded together. For instance: base coat color, can have a chemical bond with clear if the clear is sprayed within 24 hours of base coat application. Times vary by product brand but the information is usually available on the paint can or on the product application sheets available (usually free) at the paint store.
Substrate: Applied layers of products up to the application of paint is the substrate.
There is a reverence and discipline that need to be kept with respect to substrate. Your substrate starts the minute bare glass is exposed, keep it clean.
From this point on oil, gas, grease, spray lubricants, silicone lubricants, hand lotions and any foreign chemical substance is your enemy. Even oil from your hands can cause substrate issues. How you ask? Fillers & primers are porous and will absorb them, it's very hard to remove them completely. In some cases, I've had to remove the problem area of all substrates and start all over. I've seen wd40 mist/fumes float across the room and ruin the following paint application. I can't stress this enough, friends who come over to check out your work always seem to want to see with their hands. They just can't help it, they have to feel how smooth the primer is........ This is NOT OK.... I keep a used sanding block available to slap some sanding dust in my hands to absorb the oils before touching the substrate. Once you start sanding the dust sticks to your hands and keeps oils dried up. If your friends want to touch, slap their hands with it too. I've startled more than a few by yelling "DON'T TOUCH THAT" in an aggressive tone. :D
It's very risky to combine mechanical and paint work. An engine change while the car is in primer is very risky. Kid with a chocolate bar, oh no, No, NO!......... Don't even think of lubing the door, hood or top hinges with any kind of spray. There seem to be an endless source of these contaminates, keep the discipline. Lacquer thinner can work to clean bare glass but often will remove primers.
These foreign substances impact adhesion, paint will not stick to oils and other substances, if you spray primer over it, it will absorb up into that layer too. The paint may even go on ok, but the hot/cold cycle of shrink/expand will soon separate the layers causing a bubble under the paint. Silicone is the worst as it causes the paint to repel away from it like the same end of two magnets. This leaves a paint void, usually a small circle (fisheye) in the paint. These are not often visible in the primer, usually showing the first time when paint is applied. They make fisheye removers but the ones I've tried don't work very well. It's much better to keep the discipline of substrate cleanliness. Washing bare glass with dish soap and water then letting it dry completely before the first coat of primer is a must.
Keeping the substrate pristine isn't as easy as it sounds. Try to limit the time of exposure by moving forward with the work at every opportunity. If it's got to sit for awhile put a car cover on it and don't store anything on top of it.
One question I hope you can answer on oil grease on fiberglass. I have a project 68 that I bought off someone else that was midway through. The paint is all stripped off and bare fiberglass present. I noticed areas that oil has been dripped on and can see it is saturated. I know that this will pose problems later as it migrates out. Do you have any suggestions on removal of oil/grease from fiberglass? thanks for this series. Best on the internet.
· Premium Member
Discussion Starter · #143 ·
Thanks for your kind words.
That's a tough one, wax & grease remover & lacquer thinner can remove surface oils (see post #37). If truly saturated those areas will likely not adhere permanently to substrates or fiberglass repairs long term. IMHO it's best to plan replacement panels or patches to remove them.
· Premium Member
I concur with 7TRoadster, panel replacement is the only sure fire way. I followed his guide with only one exception - after the body was stripped down to the glass I sprayed it with black epoxy primer from Southern Polyurethane. I was having medical issues at the time and wasn't sure when I would get back on the project. I wanted to seal the glass to avoid contamination. When I recovered, I resumed the procedure in the guide.
For dealing with your oil contamination one thing you DO NOT want to do is to attempt to remove the oil with any kind of solvent. It will only make it worse. However, I did hear of a technique that might be worth a shot as a last resort. Bear in mind I HAVE NOT tried this so it's still rumor at this point. Try it at your own risk, but if you have to replace panels anyway you don't have much to lose.
Here's the story: Get a quantity of fresh, unused oil dry. That's the granular stuff you use on garage floors. Put some in a container and grind it up until it's just a powder. The finer the better. Rub some of the powder into the contaminated area, then "saturate" a clean linen rag with the powder and place the rag over the area in question holding it in place with masking tape. Let it sit for a day or two, preferably outside where the sun will warm the panel. Then remove the rag and thoroughly vacuum the area. This is where you have to roll the dice. The epoxy primer might be a good idea since it sticks so well, and MIGHT insulate the subsequent paint materials. Again, I HAVE NOT tried this. If the contamination covers a large area then I would probably replace the panel.
And thanks again to 7TRoadster for sharing his technique!
103917
· Premium Member
I commend you 7TRoadster the time it must of taken to type all that information to share with anyone wanting to repaint their corvette is amazing. Your knowledge of the process and the in-depth instructions are better than you would find in manuals on the subject. If I were to take on the task of repainting a corvette I would refer to this thread and probably print it out to have as guide. Thanks flor sharing your knowledge.
Resurrecting an old post, but just want to say how much this post has helped my in getting my '80 Corvette ready for paint. Working on completing the stripping of the old paint and starting some body work and fitting the new bumpers. Thanks for the great post.
· Premium Member
Discussion Starter · #150 ·
Thank you both for your kind words. They are appreciated. Divorce forced the sale of my auto restoration business property and decided to retire. Although not painting any longer, I'm glad to know that the information passed along is being used to keep Corvettes on the go. I still have my 1970, it's up on blocks for now. Best of luck on your projects.
7TRoadster, got a question for you if you have a chance. This deals with the bumpers. I have an '80 Corvette and am replacing the old bumpers with Tru-Flex bumpers and it looked like you painted yours on the car. Is there any concern with doing this and not doing anything with the mating surfaces? Would it be better to paint the bumpers off the car after they have been fitted, or perhaps even lay your primer down on the bumpers separately, install them on the car and then do the color and clear coats?
Thanks in advance for your time on this.
· Premium Member
Discussion Starter · #152 ·
As I'm sure you probably know any replacement bumper isn't going to fit as nice as we would like. Due to tolerances engineered into the original body fitting of the flexible bumpers from the factory wasn't perfect.
IMHO it would be better to fit them up, do the body work and then prime and paint on the car. If they are fitted then removed for painting you must get them installed back in exactly the same place. By removing them you risk mismatches in the body contours you just worked so hard to match up.
I've always attached them, did the best adjustments possible, then addressed the body work, then prime and paint on the car. Removing them after fitting is not something I ever did because the chances of getting the bumper fitted back into the exact same places is pretty small. Also catalyzed primers can crack if flexing occurs while reinstalling. Better to do that on the car too.
Hope this answers your question.
That answers my question. Thanks, I appreciate it.
