Ok so I had posted a few times on the master thread with some of my issues.
I decided that it would be best to start a thread and see if anyone could lend me some of that knowledge that I know is out there.
Here is my issue I have a 03' Z06 that I bought last year. yes I know I should have but the CLB in right away. I didn't. It locked up on me and I could not no matter how much I banged the steering wheel back and forth could get the column to unlock. I deemed that the column must have locked before and decided that it had had enough. I figured that if I did a little reconstructive surgery, (the pin is no more....) that I could then install the CLB and be on my way.
Well all is not well. I am still getting the "remove key wait 10 seconds" and "service column lock". I'm thinking that the only way for the CLB to work is the computer has to get the signal that it is unlocked before installing the CLB. My column lock was never going to unlock..... I've tried pulling fuses with no luck. I tried to drive it and it died at about 2 mph...
I'm looking for thoughts on what I should try.
Please don't post "You should have installed the Column Lock Bypass when you bought the car". I got it, I screwed this one up.
Thanks for any help!
Justin
Justin
