mine doesn't even have that bracket :laughing: :rolling:
Sometimes you have to feel like an archaeologist. :laughing:I have a November 67 build car. An "early" 68, the most peculiar of all C3's. Many people are aware of the differences between these cars and later however, I have never seen my newest problem identified.
I replaced my rear with a 76 diff. I used the nose bracket (mounts the front of the differential to the frame) and had to change to a drive shaft with 1330 U-joints. Bolted everything in, no problems.
I checked the pinion angle after mounting and it is at 0 degrees to horizontal. It should be at 3 degrees, nose up! I also noticed my pinion yoke is very close to the nose bracket. Looks farther away in this picture but believe me, it's too close:
So after giving up on trying to find the problem, I decided I would get a new nose bracket and modify it to correct this "problem". I looked in Paragons catalog and, guess what? A 68 uses a C2 nose bracket and 69-up use a different one:surprised. In the almost 4 years that I have had this car and all of the times I have seen 68 differences discussed, I have NEVER seen this issue mentioned.
So if your having problems setting your pinion angle, you might want to look at the parts you have.:thud:
Anyone have a nose bracket for a later C3?
The general strikes again.:rolling:I have a November 67 build car. An "early" 68, the most peculiar of all C3's. Many people are aware of the differences between these cars and later however, I have never seen my newest problem identified.
I do the same however in this case, it would not have occurred to me that the 68 was different than the 69-up. I don't think there is any number stamped on them either.I've owned my '68 long enough to learn to check the AIM and original part numbers on just about everything before doing anything. Experience teaches.
