Hey guys. I have a no start issue that I have done much reading on.
Turn the key and I have lights and accessories but no starter.
I have 12.2 volts from a brand new battery to the brand new starter big lug.
I have replaced the starter, starter relay, new VATS key, a VATS bypass switch from Zip (all correct resistance), no security light on, no power to purple wire at solenoid when key is turned. If i jump the starter solenoid it will spin. HEEEEEELLLLPPPP!!!
Charles
Not. A direct answer, However I to have a 90 vert and it began to shut off at will , It was tow to my tech and after several attemps it turned out to be a rodent chewed the insulation from wires top of the transmision close the rear of the Engine . Just another though, good luck.
How the heck did you see that? I tried looking back there and it looks like i would have to tear the top of the motor apart to see it.
Charles
