Again, I'm posting this rather than than PM in case others are dealing with the same thing....
Got my posi on the bench with Gary's kit in it & setting it up springless. Never done a differential before. I have the .035" shims in, .040" was absolutely siezed. I have two "issues" which may or may not be "problems".
First, I don't know what the "feel" should be for stiffness. With the unit on a yoke in the vice, a bolt tight through a ring gear bolt hole and using a beam torque wrench at 90* from the axis, I read 25-30 lb/ft to turn it. The shop manual calls out minimum 40lb used, 70lb new to turn the axle with a torque wrench on a lug nut, on car. I figure I'm probably in the neighborhood of minimum for used. (Adding 20% for added torque wrench length from my point on the ring gear (which I figure roughly correlates to a lug nut) to the true axis of the unit, I figure a true torque of about 30-36 ftlbs to turn posi unit on yoke.)
Installing the other yoke with a bolt in a u-joint strap hole, I read 12-15 ftlbs to turn it yoke to yoke.
Are these acceptable torque values? Seems awfully light to me.....
Second, as I turn it it pulses--it's 'bumpy.' My actual torque reading goes 25-30-25-30-25-30. It seems to correlate to the teeth of my spider gears rolling over the side gears. This can't be right, can it? It has gotten better as I've been working on it, but does not feel like it will go away on it's own. These are my original used gears, in good condition and I have radiused the gear teeth of spiders & side gears.
Third, a question: Would using shim stock instead of grinding shims be OK? I have some .002" shim stock I could use if needed.
Thanks, John
Thanks, John
