1 - 13 of 13 Posts
so i found a crazy deal on some c6 wheels and tires for my 78. BUT i have 3" studs on each corner because of my prostars. so.... what do i need to do to make these fit? just stack on spacers? dosent sound too safe. what do i need to do? thanks for all help.
You will have to use 2" or 2 1/2" adaptors, They bolt on using your studs, then they have another set of studs to bolt the wheels on with.
will they work with the 3" studs i have on there now?
Discussion Starter #5
thats what i wanted to make shure of before i bought them. looks like im stuck with a wheel made for the c3 unless i change the studs.
so the search continues.......
Discussion Starter #6
how safe are the adaptors to use anyway? i may be able to get these to work. im getting these 18/19 for a crazy price with tires
I have 2.5" spacers running on my 1980.
I've had absolutely no problems whatsoever with them.
Stock style Vette Y2k rims.
Stock wheel studs
Spacers are from ebay and are Hub Centric (< $200 shipped)
Poly bushings everywhere
Bilstein sport shocks
Yes, I've tested the suspension and tire/wheel/spacer setup, LOL.
Here are a couple more pics!
SOMFormula Quote:
Stock wheel studs
Your Vette look really good with those tires and wheels.
Did you lower the car or is it stoce height. I'm working
on my 81 coupe (pics on my sight 1stvtt1981)?
I like those wheels but on some cars they have too much space between the top of the tire and the wheel wells.
Are your tires 255 40 17?
Good thread, lots of info to be had. Thanks.
Discussion Starter #11
here they are sitting next to the car to get an idea.
now ill have to give them a real good cleaning.
Discussion Starter #12
i have not changed the stance, but im not really shure what the last owner did to it. he did some mods, but im going to go through everything in the spring next year.
Some aftermarket wheels have indentions between the stud holes that will clear the factory studs when you use the spacers. Most OEM wheels do not have these clearance holes. If you want a 2.5" spacer, then you will need to cut your existing studs down below this length, or swap out the studs for OEM ones.
I put 1" spacers on my 72 so the American Racing Torq Thrust Originals will fill out the rear fenders. The wheels cleared the factory studs just fine.
1 - 13 of 13 Posts
