My power antenna is bent pretty bad and im not even sure if the motor actually works. Would it be easier to just install a fixed antenna? If so where could I find one of those for cheap to fit the 81. Thanks in advance.
most of the corvette mags sell the fixed antenna. (mid-america, ecklers, etc )
or, you can use a newer power antenna from a GM car. the replacement antenna for that year is called a "slim-line" and the only mod you'll have to make is probably a small bracket to mount it.
