I'm Pulling And Rebuilding My 350, New Flat Pistons, Rings, Crank Turn, Etc. Does It Need To Be Re-balanced.?
Are new rods included in the etc or do you want to reuse the rods and crank ??? If the pistons are heavier/lighter than the old ones then you'll have to get it balanced.New Flat Pistons, Rings, Crank Turn, Etc.
THEN I HAVE TO FIGURE THE BEST METHOD OF REMOVAL
WITH A HOIST.
yikes, that looks like a bold strategy to me :lookinup:This is how I got mine out:
Pulling it out was a piece of cake..... I was a little more careful when I installed the new engine:yikes, that looks like a bold strategy to me :lookinup:
check this thread for some good advice. Grumpy is no stranger to pulling engines:
http://www.digitalcorvettes.com/forums/showthread.php?s=&postid=488866#post488866
Buy the Helms "Shop Manual." It will answer 95% of your questions. We will supply the rest.:thumbsup:Keep The Advice Comin Guys....i'm A Good Listener And I Really Need It Cause I'm Venturin Into Unlknown Teeritory Here. I'm Tryin To
S T R E T C H The Budget. I Have A Knock I N The Lower End And My Tilt Tel Is Still Loose.! So I'm Trying To Figure The Easiest Way Out To Get
Her Up N' Runnin For Summer.
I went from the side too. I even left the hood on.You cheated and went in from the side. Nice job not taking the radiator support off, I don't know if I could have gotten away with that.
