I keep having random issues with my bayyery being drained. I looked up the DTC Codes and found these:
BCM:
B0433 H: Rear Defogger Relay Circuit
B2528 H: Horn Relay Circuit
B2578 H: Right Front Turn Signal Monitor Circuit
B2583 H: Left Front Turn Signal Monitor Circuit
B2588 H: Column Lock/Unlock Drive A
B2593 H: Column Lock/Unlock Drive B
AO - LDCM:
B2282 H: Battery #1 Circuit
B2284 H: Battery #2 Circuit
U1064 H: Loss of Communications with BCM
A1 - RDCM:
B2283 H: Battery #1 Circuit
B2285 H: Battery #2 Circuit
A6 - SCM:
B0851 H: Battery 1 Out of Range
B2605 H: Seat Front Vert. Position Sensor Failure
BO - RFA:
U1255 H: Serial Data Line Malfunction
C2120 H: TPM System Malfunction
C2121 C: TPM System Programming Malfunction
Any ideas what to do to fix the problem?!
BCM:
AO - LDCM:
A1 - RDCM:
A6 - SCM:
BO - RFA:
