1 - 13 of 13 Posts
Anyone ever had any luck straightening out a bent fan? I have a friend with a 72 BB fan with the little tips. Seems that when shoved inside the shroud, it gets bent. I have always heard that it is narey impossible, but no one makes this fan.
· DC Crew
Offhand I would say no, you can't. But, anything is possible. How bad is it bent?
· DC Crew
I have yet to see it. It is the 72 BB with the tips. I believe all the tips are bent.
You know bro, I would try http://www.pipersauto.com/. He is a canabalizer and has just about everything ....
He is a grouchy old bastard :laughing: but knows his Vette parts! :thumbsup:
Hope it helps!
SH!T!!! Yep, got crazy and now I feel like a total jackass. Getting on the freeway Thursday - thought I'd show off for my brother - dropped it into second and dumped the clutch - did a 360 and ended up in the median. Bent the fan and crunched up the front end some. Never again. Thanks B2B for trying to help me out. Here it is:
that don't look all that bad, I would try and bend them back with a lil heat. just go slow and be sure and get them all the same. Its not a thermonuclear reactor or a swiss watch, but they need to be as close as possible to prevent a new vibration.
Or take the oportunity to snatch the mechanical fan and clutch and go electric
IF you do decide to heat and bend the tips, clean all the paint off first, then look very carefully for cracks. I'd use a magnifier. It'd be a real bite to get everything straight and looking good, then throw a tip thru the hood.
Tim
· DC Crew
Tim
I couldn't agree more. No way would I put that fan back in service. That, IMHO, is a disaster waiting to happen, not only could you throw it through the hood, you could lose your radiator as well. I would also be suspect of the water pump, it may have taken a fatal shot ....
Not trying to be doomsday here, but that is just the way I see it. Do you have any insurance coverage because it was an accident?
Discussion Starter · #10 ·
:agree: Listen to them John. I know it's worth $300, but it's still trash. Don't make me drive out there and install a restrictor plate.:rolling:
Thanks and you're right. When I had it off to blast and paint it a couple months ago it already had a slight crack in one of the blades before my little trip through the weeds. Maybe I should consider a Jeep instead.
I think I'm going to just put another fan on it for now but I sure would like to find another stocker somewhere. Been checking ebay.
· DC Crew
1 - 13 of 13 Posts
