Here is my somewhat complete list of specs and mods.
Engine
CNC machined dry sleeved LS2 engine block - 4.125" bore – 427 ci
4" 4340 forged steel crank
Billet steel connecting rods
Forged aluminum ceramic and teflon coated pistons
MTI Stage 3R ported and polished racing heads (336 cfm intake, 240 cfm exhaust)
Ferrea stainless steel 2.080" intake and 1.6" exhaust valves
Custom double valve springs
Titanium retainers
MTI custom DR1 camshaft - 116 LSA 228/232 duration at 0.050 and 0.588/0.574 lift
Jesel 1.7 ratio high performance roller lifters
MTI hardened push rods
High volume oil pump
MTI Underdrive crank pulley
160 T-Stat
MTI Custom high flow air intake system and manifold (modified FAST intake)
Kooks SS 1 7/8" full length headers
Kooks 3" X pipe with high flow cats
Borla Stinger Catback with round tips
MTI custom tune
Drivetrain
Spec Stage 3 Clutch
Spec Stage 3 Billet Steel Flywheel
Hardened Output shafts L & R
Brakes
Stoptech BBK - 6 piston front/4 piston rear, 14" zinc coated rotors, SS lines, Motul 600
OEM Z06 brake ducts
LGM G2 Spindle duct plates
Suspension
Pfadt adjustable coilovers - 16 setting
Pfadt adjustable front/rear sways - poly bushings
Corner weighted
Devilray console
Devilray seat covers
Devilray plaque
Corvette Door Sill covers
Pipedreams door saver bumpers
Sharkbar harness bar
Corvette partition
Custom C6 Decal designs visor decals
Stereo/Electronics
Stock Bose Head Unit with Navigation and HUD interface
Dynamat Extreme in doors and hatchback
JL Audio Amps 250.1 (sub), 300.2 (front)
JL Audio Stealthbox
Dynaudio 240 mk ii front components
JL Audio Cleansweep IPOD connection
Valentine V1 detector w/ great lakes visor mount, invisicord
Exterior
OEM Z06 front/rear body kit
GM Full length rear race spoiler
Southern car parts tail light seals
SS Corvette lettering
Wet sanded clearcoat
Devilray quarter panel logos
Pipedreams “Objects are Losing” mirror sticker
Elite Engineering lift rail rocker protection
Engine Bay
Pipedreams Dream kit
- SS brake booster,
- SS Alt cover
- SS fuse box cover
- SS Oil cap
- SS oil stick
SS brake res. Kit
SS Plenum Cover
K&N Breather Oil cap
Devilray painted fuel rail covers
Wheels
CCW SP-550 Devilray custom wheels 19x10 front, 19x13 rear
Michelin Pilot Sport 275/30/19 front, 345/30/19 rear
MTI Custom Center caps
Other
Priority Start Battery Saver system
Racehawk OBDII system
Battery Tender plus
OBDII code reader
NEXT MODS UP
DTE 3.90 Stage 4 Differential
150 shot dry NX kit with wideband AFR, Fuel PS, Remote bottle opener, Bottle warmer, A pillar gauge cluster, RPM window switch, purge kit, blowdown kit
MCM carbon fiber hood
Rework inside leather from pure ebony to ebony/red split– door liners, ebrake/shifter boots, shift knob, seat bolsters, trim color change
