Dedicated shops are usually the best. They deal only with corvettes and will be money well spent. Go cheep and walk home.
It does seem the only way to go, given the sometimes unusual engineering and commitment to cutting edge technology. It took me some time and investigating local garages with some minor fettering work on my newly purchased used car before a lady making a right turn replied to my question of where she takes her car for service, "J and D" Corvettes, the only place that didn't try to rip me off for oil changes" I was asking everyone, even leaving notes on windshields of the parked Corvettes over at the local aerospace company, where a lot of engineers are employed. Since then I have learned that professionals call associated shops and ask around that way , to see who is good. I learned long ago, and the hard way, about old cars, that it is not the price of the work that is critical, but who is doing the work that matters.Dedicated shops are usually the best. They deal only with Corvettes and will be money well spent. Go cheep and walk home.
I agree, do to some of the engineering choices, and traditional incorporation of new technologies , a person not familiar with the old car might struggle to be productive . To put it politely .Dedicated shops are usually the best. They deal only with corvettes and will be money well spent. Go cheep and walk home.
Thanks for the informed contribution. I held off with this reply, trying to gather as many replies as possible, but it seems I was fishing in a dry stream, since people routinely replay to posts from years ago around here, so no surprise things are pretty slow.For the torque tube and from Chevrolet directly you should source 3 bearings. 2 will be the same part number. These bearings spin at full crankshaft RPM. The TT is an extension of the crankshaft when your foot leaves the clutch pedal. But they see no oil. Ever. And it is a big job tearing out the TT so whatever way you go you really want to have confidence in it. Because dry and loose bearings sound terrible inside a hollow aluminum tube.
There are 3 o-ring seals that go in the housing of the torque tube at each bearing race to prevent it from spinning in the loos-ish fit.
There are 3 or 4 snap rings that go on the front and rear yokes where the bearings slide on and in the rear bearing housing. Maybe 5 or 6 including those. If you are careful and don't over stretch them you can re-use the snap rings and I have several times without problems. But we are supposed to change them all even the big one in the rear as per GM service recommendations.
There is a 'slinger' which is just a washer that presses on the nose of the front yoke and just in front of the front bearing and it keeps the clutch dust and other contamination from getting to that bearing from the bellhousing. This is a cheap part and it is hard to re-use
And there is a lock nut on the rear yoke that needs to be changed when you put the 2 bearings in the rear of the TT.
The best results you will get with the driveshaft couplers will be with factory parts again sourced from Chevrolet as they will be German made couplers just like what is on all the euro cars. The cheap aftermarket couplers live a short life.
The semi solid and solid couplers, even with the carbon fiber shaft make noise and transmit NVH (noise, vibration, harshness) to the rest of the vehicle. There used to be a good solution for this from Prothane in their '6 shooter' driveshaft couplers. They were semi solid aluminum couplers with urathane busings at each bolt. These were nice but are very hard to come by anymore. And as they wore they still made the NVH.
There is absolute brilliance in the factory produced parts. Done right you never know the torque tube is in the car.
The clutch hydraulic system has been broken down into just 2 precharged parts each with it's own quick connect fitting. These are the slave and the master. There should be no need to bleed past assembly. When it is apart these items should be changed and then they should be expected to last the life of the clutch. From where I stand the remote bleeder is a device to introduce air into the system. Because how could it remove what is not there? And that is how this hydraulic system was designed and intended to be serviced by the manufacturer.
The pilot bearing should be changed with the clutch or if it is making noise. But the clutch has to be broken down to access the pilot bearing. So if it is quiet and you just put a clutch in it there should be no need to worry about that.
