It appears that my rear bearings are shot which is causing uneven wear on the passenger side rotor and some interesting noises. I have some new drilled and slotted rotors coming and will do a few other things:
Replace bearing/hub
Replace shocks
Replace all 4 rotors and brake pads
Lower and allign
Next weekend should be a busy weekend...
Right now its drivable, just crank the stereo or keep it in lower gears and listen to the mufflerless exhaust
Replace bearing/hub
Replace shocks
Lower and allign
