a scan tool like snapon would help but here are some do,s and dont,s .dont let master cyl empty,dont shake brake fluid [air bubbles],dont push brake pedal to floor. some do,s have some one in car ,you loosen rr bleeder ,put your finger over bleeder hole have aide slowly pump pedal ,psi will make fluid go past your finger but seal it on up stroke [watch out for spray] do this until cyl is almost empty ,refill,do other 3 wheels. let the car sit for 15 mins. if ya have a safe pedal slowly road test. all of this assumes that cali. slides are free and rotor is secured. still no good pedal ya may need that scan tool and or power bleeder. no hard pumping on pedal it induces air
